sudo apt-get purge 930
Got some extra cash
I've got the engine out to fix the oil leaks. Erik can testify to the leaks. I'm certainly buying a Tial wastegate and K27-7200S turbo because my stocker is ****. My question: should I buy the 930 tensioners or Carrera? I've heard from many praising each as better than the other. Which is it?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Nobody has an opinion?
what year is the motor, I dont know much on the subject- what is the diffrence between them? I got my stockers in my car and they seem to work well
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
It's a 1979 RoW with old style tensioners. I've heard people talk about how good the 930 tensioners are and I'm wondering if they are better than the pressure fed Carrera tensioners or not.
A fellow Pelacanite
If you're tensioners don't have oil lines running to them then git rid of them NOW.
Pics?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Thanks.
I don't really have an opinion on which tensioner is better, but if you want to join the bandwagon I put Carrera tensioners on my '79 930
2014 Cayman S 2011 Cayenne Turbo 1979 930 (475 rwhp at 0.95 bar) |
L:et me know if you need a waste gate. Also I feel the carrera tensioners work wonderful
Ben 914-6 2.4s GT tribute. 914-6werkshop.com manufacturer of 914-6, GT, Conversion parts |
A fellow Pelacanite
Are you guys saying we can buy 930 oil pressure fed tensioners that are different to the carrera ones?
Carrera tensioner are the ones that were oil fed... typically used as an update on the 930 and older 911s when getting a service or doing a build.
The standard 930 tensioner is not a hydraulic oil fed unit.. it is good... but supposedly oil fed carrara tensioner are better as they are pressurized. I have seen some of those fail also, though not as many, and not with as disastrous results. Of course with the standard 930 tensioner you can always add the locks to keep them from completely compressing if they fail.
RGruppe #180 So many cars.. so little time!! |
Macht Schnell
Hello,
I have an '85 930, it has the pressure fed tensioners from the factory. I always thought that when the 930 got the Hydraulic tensioners that they were the same as the Carerra, basically a convergence. If that's true, that should answer your question. I think you can look on Pelican and see if it is the same replacement parts for Carerras and 930's. I believe they are the same.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
In essence if it's the hydraulic tensioner being addressed then the Carrera and 930 part are one and the same. P-
Im starting to think there is no diffrence in the carrera or 930 chain tensioners. Maybe they just called them carrera tensioners because the carrera was the first one with them. So in 87 when the 930 got them; "the new 930 for 87' is updated with carrera tensioners...."
Correct..!!!!
I deserve a cookie!
Ordered the Carrera update kit and turbo today. Waiting for Ben to reply to my email about the wastegate so I can get it ordered. Woohoo.
I listed an intercooler on ebay that might interest you....
Pat K 87 930 Slant |
Thanks. I'll keep an eye on it. If the price ends up very right on it I may go for it but I am more interested in a drop in.
Thread Tools | |
Rate This Thread | |
