Brando
Extra fuel pump with low boost?
Do I need an extra fuel pump on my sc with 4-5 psi?
Just in the finishing planning for the installation of the 930 stuff. Anything I need to fab for this swap or it going to be bolt on for the most part? Will it be a day job? Thanks, BA
Turbo powa! 1977 911s. it's cool |
What is your objective?
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Brando
Objective with the single fuel pump?
Well it's not buying anothe fuel pump till needed. Objective with the 930 stuff? More power and a stepping stone till the engine gets tired. Then I'll put lower compression pistons in and build a proper turbo engine. Thanks
good luck
good luck
Stranger on the Internet
No, you don't need one.
Patrick E. Keefe 78 SC |
No not a day job
Stephen 94 3.6Turbo 6-speed AWD |
Well that's easy. Mount the turbocharger and do a run with wideband-lambda. If it goes lean, your fueling isn't up to snuff
Thank you for your time, |
Brando
Comeon, it's just bolt on! Right?
Well, I realize there so many little things like bad vaccume lines that can throw your day off and odd stuff like that, but it is just bolting stuff up, is it really hard to reach stuff and such? I guess I should order some stuff like the gasket to the oil...I don't even know what to call all that leaky stuff back there, but I guess there are lots of things to do. I guess I'll give it some more thought. Thanks guys.
Ben 914-6 2.4s GT tribute. 914-6werkshop.com manufacturer of 914-6, GT, Conversion parts |
Brando
Thanks Ben. By the way, you still got one of those sump covers with the drain bung?
Thread Tools | |
Rate This Thread | |
