-   -   What are the benefits of v-band? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/394899-what-benefits-v-band.html)
polizei 02-25-2008 04:06 PM
I have seen Precision and Garrett turbine housings advertised with v-band outlets. What are the benefits of v-band? If someone has a good link explaining the benefits, I'd appreciate it as I haven't found anything yet. Thanks!
copbait73 02-25-2008 05:28 PM
V-bands are a quick effective means to make the attachment in this location. However the turbocharger must be mounted off the turbine housing and a v-band can not be used for mounting it (on a street application), therefore you would need to bracket the turbine inlet flange.
polizei 02-26-2008 12:26 PM
Thanks! I guess it'll all make more sense shortly as I just purchased the Precision SC6162SPR from TD Autowerkes.
beepbeep 02-26-2008 11:11 PM
You can rotate the flange in continuous fashion until the position is right. Also, it can be undone quickly.
930gt-40r 02-29-2008 03:15 PM
I wish I could get Tial's V-Band inlet and outlet housing, It is soooo cool and flows even more than a normal housing.
