930 trans fluid what do you use?
I just had my trans rebuild in my 930. It has run Swepco 203 up to this point but Swepco is becoming harder to get here is Seattle. What other opptions are people using and why? Please help.
73 911 E 86 911 Turbo - Sold 01 Boxster S 08 Cayenne S |
Smart quod bastardus
Swepco 201 exclusively.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
I use Swepco and buy it from Pelican, seems to be always available this way.
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
Porsche-Poor
swepco 201
1979 911 RS clone hotrod 1983 930 turbo-sold, will be missed 1992 964 C2 Coupe-regrettably sold 1980 911 SC Weissach-regrettably sold 1975 911S-sold but not forgotten |
+4
Well that definately is NOT a kodak moment! Hopefully he went easy on you...
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
resident samsquamch
Swepco 201...
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
201 it is
It sounds like the Swepco 201 is perfered by a long shot. Thanks for the help
gearhead
bwbolin,
Just a heads up on 201 versus 203. You will find that a lot of the more performance oriented people use the 201 because it lack the moly additive that you find in 203. There are a lot of people who agree that that additive makes it too slick for the ZF clutch type LSD's. Furthermore, on a freshly rebuilt transmission it's just not required. If your transmission has an open differential or a torque biasing differentia, a couple of years down the road it may be worthwhile to switch back to 203 as the tranny ages. But if it has a true LSD, stick with the 201 until it's time for another rebuild. Lastly, I always tell my customers to hold off on installing 201 until they break it in. If you've got fresh synchros in there, you will want to change your gearoil in 50-100 mi. There will be particuate that cuts loose in addition to unforeseen contaminants from the rebuild process. The magnet won't grab everything, and you just spent all that money on a build so why risk it? Go down to Walmart and get a gallon of their Supertech gear oil. Put that in there for break in and then switch to the Swepco afterwards...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
good info
That is just the info I needed. Thanks very much. I was planning on using somthing for the first 100 or so miles then changing it out.
Registered Abuser
201
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
