Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
cgmeredithjr's Avatar
Wild 73 Twin Turbo Beast
Check out this lightweight terror...she's gonna be mine.
Vehicle Description
1973 PORSCHE 911 Car originally built by Loren Beggs at 911 design for previous owner at a cost of $180,000+. Now has zero-time new 3.9 liter twin turbo motor built by Air Power Racing. Chassis and Body Chassis completely disassembled and dipped to remove all undercoating. TIG welded DOM 1 3/4 very strong roll cage. Wide body 993 GT2 Composite Bodywork. Dual 993 front oil coolers with proper ducting to duct all the air out in front of the front tires. New generation 3M Control Tac vinyl graphics that are easily removable. If you find the colors too wild, the car is all white underneath the multi-colored graphics wrap. 3M clear bra paint (vinyl) protection. Flush fit Lexan windows. Carbon fiber dash. Motec ADL dash. Recaro Porsche Super Cup drivers side seat. HANS type 6 point racing harness. (2) separate 10 pound SPA mechanical fire systems. Composite roof. Cool suit system with helmet blower. 27 Gallon fuel safe fuel cell. SUSPENSION Complete ERP monoball rear suspension. Rear ERP monoball spring plates. Complete ERP front suspension. Woodward electric power steering. JRZ double adjustable shocks and struts. Kinesis 11x18 front wheels and 13x18 rear wheels (4 front and 4 rears). Brembo 8 piston front brakes. Brembo 4 piston big red rear brakes. Dual brake master cylinders with Tilton adjustable brake bias knob. Charlie bar sway bars. DRIVE TRAIN 3.9 Liter twin turbo motor based on a 993 engine. Dual Garret GT25 ball bearing turbos. Extra large custom made 911 Design intercooler. Electromotive Tech 3 crank trigger fuel injection. HKS boost controller. Carillo rods. 911 C2 crankshaft. Web cams with new EVO twin turbo grind profile. AASCO valve springs with titanium retainers. Custom made 911 Design 321 stainless steel headers. Previously dynoed 520 HP @ 1 bar of boost at the rear wheels. 612 HP @ 1.2 bar of boost when it was a 3.6 liter. New motor is a 3.9 liter with 104 mm L&N billet cylinder barrels with bigger cams, should make approx. 700 HP @ 1.2 bar. 993 Turbo 6 speed transmission converted to 2 wheel drive with custom Guard gear set geared for 175 MPH. Guard GT limited slip differential. Solid engine and transmission mounts. Electric Tilton transmission oil pump and external transmission oil cooler. 911 Design custom made 300M axels, 300M cages and Krytox grease.
Cleve
Old 02-28-2008, 03:55 PM
Built by 911 Design.
Old 02-28-2008, 03:58 PM
sudo apt-get purge 930
equality72521's Avatar
Oh my, that paint is simply horrid. Sorry.
--clutch-monkey
Old 02-28-2008, 04:01 PM
i like that paint job - its a race car, it should catch the eye.
Old 02-28-2008, 04:19 PM
juicersr's Avatar
U gonna sell ur 934 replica now? It's gonna seem like a miata by comparison to this monster.
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 02-28-2008, 04:22 PM
75'930cab's Avatar
I like outrageous paint jobs on race cars!
67 Triumph TR4a irs
72 DeTomaso Pantera
75 911 3.3 Turbo Cab*SOLD 5-11-04
73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco
Old 02-28-2008, 04:36 PM
icemann427's Avatar
Very cool!!! I'm way jealous! Have a blast with it. No one will ever mistake that car for another, that's for sure...And, I like the paint, too!
Old 02-28-2008, 04:54 PM
Well, I guess it's a good thing that it's only vinyl graphics and they can be easily removed...but I kinda like it in a demented, trippy sorta way.
Cleve
Old 02-28-2008, 05:02 PM
Wanna buy the 934 project for a screamin deal? Motor done and being dyno-tuned, transmission fresh and re-geared, suspension complete, bodywork fitted, wheels, bare 930 tub in line to receive seam welding and cage...I can sell as is or complete the project and sell ready to drive.
Cleve
Old 02-28-2008, 05:08 PM
copbait73's Avatar
So somewhere under there is a '73? How many steroid injections does my '73 need to get to that level...have fun!
Old 02-28-2008, 05:46 PM
Cleve
I didn't realize this was a race car. I thought this was street.
--clutch-monkey
Old 02-28-2008, 05:52 PM
Macht Schnell
les_garten's Avatar
Absolutely Gorgeous!! Any PIX of the interior and engine?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 02-28-2008, 06:11 PM
Les
Here you go.
Cleve
Old 02-28-2008, 06:23 PM
More shots...check out those 8-piston Brembos!
Cleve
Old 02-28-2008, 06:25 PM
icemann427's Avatar
Where's the air conditioning? LOL
juicersr's Avatar
Cleve, pm sent
'79 930/934 replica
Old 02-28-2008, 06:26 PM
beepbeep's Avatar
Hint: that fan belongs to N/A 3.6 and pulls approx 30% less air than straight-vaned turbo fan. There is a reason that factory fitted straiht-bladed fans to all turbo engines.
beautiful car! Turbo-converted 3.6 is a way to go!
Thank you for your time,
Old 02-29-2008, 12:11 AM
Great car, all the work is there, looks to be stupid quick.
Although you think with the money invested they would have put a 993 link setup on the rear. :/
Old 02-29-2008, 01:00 AM
Thank you for the good eye...I will change that to the proper turbo fan!
Cleve
Old 02-29-2008, 05:08 AM
The car of course will be road raced and driven a little on the street since it has a VIN and can therefore be tagged and insured, but here is what I think it will look good doing also...
http://www.youtube.com/watch?v=YxErY3wJ6U0
Cleve "Mamma always said I was a little slow"
Old 02-29-2008, 05:15 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
