Top End Rebuild and Turbo Project underway
Hello all,
First, I would like to thank all of you for your help and advice over the past few months in leading up to this project. I'd particularly like to thank Ben (mb911) and Kris (930gt-40r) for their time on the phone and indispensible direction. I bought my '87 Carrera last June (about 60k miles at the time) knowing that it would need a valve job at some point. I found out in the fall that the time had come sooner than expected so I parked it with plans to have my buddy mechanic help me with it over the winter. Spring is soon approaching and this project has taken on a bit of a larger scope. I initially just wanted to make a few upgrades in preparation for turbo charging sometime down the road, but ... you get the idea ![]() So here's the plan... Once the heads, cylinders, and pistons are out, they will be sent to Supertec. Henry is going to make sure that everything is within spec for the rebuild (crossing my fingers that there are no surprises). Pending a positive report, the valve job and twin plugging of the heads will be performed. I'm not going to complete the twin plugging just yet, but I figured while I'm in there I might as well for an extra couple hundred bucks. Henry's also going to recondition the cylinders and machine the pistons to an 8.5:1 compression ratio with consideration to the twin plugging. I may also have him port the heads... still have to talk to him about that. Once everything gets back to me, the top end will be reassembled with Supertec head studs. I'll also be performing a complete clutch job. ****************** *This section has been updated as things have changed* I'm not using the stock cylinders & pistons but rather a set a 3.3L mahle's with 8.0:1 compression. Due to the lower compression, we're going to increase the boost to .7 BAR. And since we were able to remove the rods w/o cracking the case, we're installing ARP rod bolts. ****************** Now for the turbo... I'm sticking with my stock Carrera heat exchangers and Henry is going to hook me up with a J pipe. I'm going to be running a Precision SC6162SPR (.63 A/R, T3 v-band, E compressor housing, Ball Bearing) from TD Autowerkes, Tial 46 WG mm from Kris, Tial 50mm BOV from TD Autowerkes, M&K Exhaust from Ben, Stage 1 ECU chip from Protomotive, BEGI rising rate fuel pressure regulator, and I'll be tuning wtih an Innovate LM-1 (still haven't purchased). I'm hoping to make 300+ bhp at .5 Bar. Hopefully after this setup is tuned, the boost will come in pretty early. Today was the ground breaking ceremony. My friend Doug and I dropped the engine and detached it from the transmission. It only took 2.5 hours to get her out thanks to Doug's expertise! Here are some pictures showing today's progress: Before: ![]() Dropping: ![]() Tranny detached: ![]() Up on the table: ![]() The only mishap from today was when I intended to remove the air conditioning compressor adjustment bolt but ended up tightening it and breaking off a small piece of the compressor ![]() ![]() We'll be working again on Tuesday and Thursday night this week. Hopefully there will be a shipment of heads, cylinders, and pistons going out to Supertec on Friday. I'll continue to post progress here.
Andy - 1987 911 Carrera Coupe Last edited by polizei; 06-05-2008 at 04:29 AM.. |
Cool project
Hi
Sounds like my kind of project. Please keep the photos coming. I really like the muffler on your carrera, what type is that. My "knowledge" doesn't allow me to interpret from your signature. Just what I am hoping to do some day in the future... Best of luck Jesper |
I replaced my stock cat and muffler with a cat bypass and muffler bypass from a comany called Fabspeed. Our host sells the cat bypass. The combo was AMAZING! It sounds really gutteral and muscle-like until about 4500 rpm. After that, it morphs into something like a heavenly scream. It truly sounds like a race car. Another benefit is the weight reduction. The stock exhaust is HEAVY. I bet you shave off at least 30 pounds with this setup. Sadly, I can't use it once turbo charged, so I've already sold them.
Andy - 1987 911 Carrera Coupe |
Very informative...keep it coming
Andy,
Very motivational in the sense of that's where I am heading too...if only I can find someone in S. florida with that kind of expertise...anybody...anybody?(lol) keep it up, Rob
Rob L. Currently have too many cars to properly care for ![]() |
andy ,
I delted your VM yesterday before hearing it by mistake. Give me a call again when you have a chance
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I'll give you a call this afternoon. Thanks!
Macht Schnell
Der Polizei,
How did you find out you had a LSD. I would like to find out about my tranny. Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
I am going to be following this closely. I'm seeing this project for my 84 in the future.
1984 Porsche 911 Targa 1974 Porsche 911 Coupe- just a tub... for now ![]() |
Doug explained it to me at the time, but I'm not too savvy mechanically :/ I believe what he said is that if you turn one of the side differential gears in a forward direction and can simultaneously turn the other differential gear in a rearward direction, that it's an LSD. I'll ask him to explain it one more time and maybe take a pic. Please jump in to correct me if I've butchered this!
1. Lift both rear wheels. 2. Pop the shifter in neutral. 3. Turn one wheel, if other spins in same direction, you have LSD. If it turns in opposite direction (or stands still), you have no LSD or worn LSD. You can also check by holding one wheel and turning the other. You should need at least 20Nm torque preload to overcome the clutch if LSD is installed.
Thank you for your time, |
Macht Schnell
I have always wondered if I had a LSD in mine. Is there someplace you can run the VIN to find out how the car was equipped? Les
I've heard that you can contact Porsche AG for the original window sticker which lists all of the options...
I belive they called it M220 option. There should be a option code somewhere on the car. Otherwise the tranny's usually had a sticker on them saying "Sperrdifferenzial". But the easiest way if just by popping in neutral, locking one wheel and trying to turn the other. If it drags, there are clutches in-between. Unfortunatly, many LSD:s are getting old nowadays (as cars are old) and are in dire need of rebuild...
Macht Schnell
I don't know Bumpkis about Diffs. I had my tranny redone and I believe he said he placed the clutches. Also, when I got the tranny back. When I turned right or left at a stop light or corner, the tires would chirp hard everytime. I was told I needed to just drive it some. Les
Day 2
Good progress tonight. We tore down all of the engine peripherals and we're just about ready to remove the left cam tower to get at the heads. Looks like we should be able to get the heads and cylinders shipped out by Friday. Here are some pics from tonight:
![]() ![]() ![]() ![]() Most of the parts should be arriving within the next few days. More pics to come.
Macht Schnell
It's pretty clean looking! You hadn't met the requisite 1" of oil grunge requirement for a rebuild! I bought some of that Hyper expensive Brake caliper paint from Eagle Day and Painted my Shroud. If you look at it from 3" away, it looks like I painted it with a Broom!! But from a foot out with all the goodies on the motor it looks awesome. Also, the paint is hard as nails. Real Pricey though, just a thought.
Macht Schnell
http://www.eagleday.com/brcapaki.html
Day 3
The engine is now torn down as far as we're going during this project. There was a considerable amount of buildup found on the valves and piston surfaces as suspected. Everything else seems to be in great condition, so I'm very pleased thus far! I initially thought that we weren't going to be able to remove the rods without cracking the case, but we ended up getting them out. I'm going to install some ARP rod bolts for some added insurance. Here are some pics from tonight:
![]() ![]() ![]() ![]() I've got a VERY heavy box packed up in my garage and ready to be shipped to Supertec tomorrow. I'll be cleaning parts and doing some odd end maintenance in the coming weeks. My guess is that it will be closer to a month before the parts get back here... And now for the long wait ![]()
