930assac's Avatar
930/66 vs 930/60
Hi,
can anyone tell me the advantages of the type 930/66 engine versus the 930/60 on a 930?
The thing is whether to choose between a 1980 930 or a 1983 unit. Which should be the main differences and advantages between one or the other model?
thanks and greetings from Spain
Johann
Old 03-04-2008, 01:22 PM
930turbo's Avatar
Choose the one with the least mileage and the best aesthetics. The difference in sub-models will be insignificant compared to those factors.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 03-04-2008, 06:27 PM
Adrenaline Junkie
Hayabusa's Avatar
Originally Posted by 930assac View Post
Hi,
Johann
Johann, I thought you already bought this turbo?
Old 03-05-2008, 01:29 AM
930assac's Avatar
Not yet, we are having problems with the registration.
Being a 1980 year car, there is a lot of difficulties and costs to register it as well as pollution problems.
I have been offered a 1983 unit, its to know the big differences
thanks for the interest
Johann
Old 03-05-2008, 04:21 AM
krk krk is offline
Johann,
Nice cars!
I don't know anything personally -- I own a 76turbo, and spend a lot of time reading/lurking here as I work at learning more about it. (this place is fabulous, btw) I was curious to see if BA had anything in his book -- it's not much, but gives some idea of the changes. From P85-86:
"The Turbo engine received enough changes to justify a new type number, Type 930/66, for the rest of the world. Most of the changes were made to improve running while complying with the world (exclusive of the United States) emissions laws. There was a new warm-up regulator to improve cold-running performance and throttle response. The fuel distributor was modified by the addition of what was called a capsule valve to improve teh fuel enrichment when the throttle was opened suddenly during fast acceleration. The engines had a new distributor with a double vacuum unit with a temperature-contolled vacuum advance for emission control. The exhaust system was changed to by-pass the wastegate exhaust through its own separate muffler."
He also mentions "no change in horse power". I noted in the back, there was a small uptick in torque.
hth.
kim.
Old 03-05-2008, 09:48 AM
930assac's Avatar
Thanks to you all,
although there are differences between the american and european versions (HP) the 930 series engine has the same base and the same compression ratio depending the accessories mounted.
look at turbos against atmospheric and you'll see ratios 6,5:1 or 7:1 against 9:1.
What I meant is if the 66 series engine is more reliable than the 60's one
regards
johann
Old 03-06-2008, 08:45 AM
DW SD's Avatar
the earlier one is simpler and likely more reliable, if everything else is equal, which is rarely the case. early designs for emissions efficiency were retrofitted and often required significant trade-offs.
I'd use maintenance records, over mileage (or kms) as the determining factor if decided between two very similar engines.
Doug
1971 RSR - interpretation
Old 03-06-2008, 10:24 AM
