3.5 Yes or No?
I am on the verge of rebuilding my 1980 3.3 turbo. I have a set of 3.5 Mahle cylinders that are brand new. I am going with an EFI system on the engine. Here is the question. Do I go with the 3.5 cylinders? I have heard quite a few arguments against this modification, mainly boring the spigots and potential cylinder sealing problems. I do not plan on running more than 1.0 bar with a 8.1 compression ratio. So what do you think?
Thank you.
Old 03-02-2008, 10:19 PM
A.Wayne's Avatar
You already have the P&C so your concern is to use or not to use. I'm not a fan of the 3.5 conversion on a 3.3 , better to go 3.4 ........Is your 3.5 from andial ?
Old 03-02-2008, 10:25 PM
I have heard rumors of slip fit 3.5's. Can't remember who was making them though. Doing a search may bring back some results.
I personally stuck with the 3.4 upgrade. I didn't like the idea of machining the case, and once its done, there is no going back. If it was good enough for the yellowbird it is good enough for me...
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 03-02-2008, 10:39 PM
935TURBO's Avatar
Hi Richard, that's the upgrade I started....and yes, first of all, you must consider that the engine case will have to be machined carefully....as you can see here....
New Member Presentation
I got MAHLE 3.5/7.5/1 and 962 twin plugs heads....
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 03-03-2008, 12:16 AM
930gt-40r's Avatar
Is there a possibility of getting the spigots machined for O-rings like the 993GT2 utilizes? I would think that this would be optimal.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-03-2008, 09:48 AM
Smart quod bastardus
fredmeister's Avatar
Is there anything wrong with machining 1mm off the outer diameter of the 3.5 barrels so that you don't need to machine the case?
It should not weaken the barrels anymore than the 3.4 since it is only 0.5mm on the radius or wall thickness....at least it seems negligible.
Just a thought.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-03-2008, 02:38 PM
935TURBO's Avatar
Just a thought.
Don't know if it's a better solution....?......
Old 03-03-2008, 03:30 PM
Wayne,
At this point I only have the cylinders. I am going to have a set of pistons made. I purchased the cylinders and they came with 11.5 to 1 Cosworth pistons. I got a great deal so the pistons are extras. I do agree with you on the 3.4 prefrence. I just hate to spend the extra money on 3.4's when I already have the 100mm.
Old 03-03-2008, 06:39 PM
A.Wayne's Avatar
If you are going to have pistons made , then i would go back to cosworth for a lower comp version.
Old 03-03-2008, 07:34 PM
Macht Schnell
les_garten's Avatar
Originally Posted by Richard Buckner View Post
Wayne,
How about selling the cylinders?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 03-03-2008, 08:11 PM
Why Cosworth and not JE?
Old 03-04-2008, 07:33 PM
Are you interseted in the cylinders?
Old 03-04-2008, 07:35 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
