930 rich running fuel pressure
We are out of ideas. This 1978 930 has had 3 different regulators all set to factory specs. The last one was set up to adjust for the ever changing fuel pressure. After a short drive the car starts running very rich. We checked the flapper and cleaned and set all the recommended devices according to the factory manual that was published in 1970s. Any further developments since then? Has euro injection,Twin plug heads 1 bar boost etc. and generally use 108 octane leaded fuel. One good thing is no worries of burnt pistons.
Old 03-03-2008, 11:05 AM
plunger hanging up in the fuel distributor? return line obstructed? does it have the enrichment solinoid? If so could be trigering to fast.. I am assuming this is only off boost that you are having issues?
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 03-03-2008, 11:13 AM
also not familar with the second fuel pump not sure when that is suppose to run but I don't think it runs all the time but could be wrong
Ben
Old 03-03-2008, 11:16 AM
A fellow Pelacanite
NathanUK's Avatar
Both pumps always run together.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-04-2008, 12:44 PM
was not sure but thanks for clarifing
Ben
Old 03-04-2008, 02:01 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
