Manassas, VA
lucittm's Avatar
Question Can Anyone Identify This Part?
Specifically 965 Owners,
I need help identifying this part. It is located on a perch above the Aux Air Pump. The cadmium plated part secures two electrical cables at their connection points. One of the plastic clips is broken, hence the zip tie. The other clip is MIA. I am assuming the part comes complete with both plastic clips, but I really only need the plastic clips.
If someone has removed their Aux Air Pump and related smog equipment for track use, you might have the part I need.
Or, if someone can provide me with a Porsche part number, I will gladly ask our sponsor to source this part for me. It is not in the parts diagrams that I could find. Maybe it is in the current PET?
Thanks for looking,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 03-04-2008, 03:21 PM
Trace the wires and see where they go to. If I rember that looks lihe the plug for the o2 sensor. If not it would be the change over valve, pt. # 19 in pelican parts dia. under aux. air pump lines. good luck.
Old 03-04-2008, 07:15 PM
Looks like the o2 sensor plug to me also,,if it goes down through the tinware at the side and into the exhaust thats what it is!
Old 03-05-2008, 10:59 AM
e p slick's Avatar
Post renal drain scupper. Probably from Guetzworkenz in Munchhousen.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-05-2008, 11:41 AM
Manassas, VA
lucittm's Avatar
...This Part?
964 T #304,
Thanks, I did find it in our sponsor's parts list, not where I expected it though. According to the database, it is Porsche part # 999-651-203-40 "Cable Holder" and it goes for a whopping $1.25.
I love this website!
Thanks,
Mark
Old 03-05-2008, 04:31 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
