After the next project
x98boardwell's Avatar
1994 Turbo 3.6 Wheel Question
The 1994 Turbo had the 3.6 3-piece Speed-lines.
The offset were as follows
Front: 18x8 with offset of 52 (part# 96536213600)
Rear: 18x10 with offset of 51 (part# 96536214000)
Will these fit a 87-930 and will I need to remove my stock spacers or can I keep them.
Does anyone know what the standard 930 offset is? Is it the same as the 964 body style?
Lastly, the part numbers were given to me by the Porsche dealership and the gentlemen that I spoke with could not verify for sure that these were the correct speed-lines. Can anyone cross-reference these part numbers or look at their's for clarification?
Thanks for your help in advance.
Bryan
Old 03-05-2008, 10:35 AM
A fellow Pelacanite
NathanUK's Avatar
The cars with ABS (the 964 series do) have a different offset to the earlier cars. You will needs spacers and the best type to get is of the hub adapter type.
You will need to work it out exactly right at the front so the centre of the new wheel when viewed from above is exactly where the stock wheel was. As for the rear it just needs to look right. You should find you need approx 30mm of spacing + the distance of any spacer you may or may not remove. Work it out exactly though.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-06-2008, 08:03 AM
Anyone else with some input? Thanks,
Bryan
Old 03-07-2008, 05:51 PM
Metal Guru
911nut's Avatar
I think the offset of the front wheels was 47 mm.
I believe Nathan is correct about the offsets and the need for spacers.
Speedline made wheels to fit the 930. Replica wheels from RH are available also.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 03-07-2008, 06:26 PM
Bryan,
What's going on man? Just get the RH wheels I love mine
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 03-07-2008, 08:32 PM
What UP?
BMAN,
How have you been? They do look great.
1) Are you using stock spacers or no spacers?
2) If no spacers, did you have to change out the studs to make them shorter?
3) What are your offsets?
4) Size of tires you are running?
5) Any issues at all with rubbing?
6) Are those the 3.6 look-a-likes or another model? If so, which model?
Thanks bro,
Bryan
Old 03-07-2008, 08:48 PM
Doing just fine
I run the stock spacers. The wheels are 18X8.5F with an offset of 21 18X10R with an offset of 15 Tires are 245-35'sF and 285-30'sR As you can see I'm sitting pretty low and It will only rubs a small bit when I make a u-turn.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 03-07-2008, 08:58 PM
cl8ton's Avatar
Thanks for that post BMAN, your tire sizes are exactly the size I am going with and have been looking for a pic with them!
Bryan, how can I ever park next to you in Fresno if you go with these rims? I will look like an idiot
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 03-07-2008, 10:01 PM
RH Wheels
They do look nice. CL8ton, when you get your rims finished then post a pic. I think you will be pleasently suprised on how your car looks. Your wheel style would be my 2nd choice.
I have wanted the 3.6 wheels before I even owned my car. Too bad I could not afford a 3.6 Turbo... that would have been nice.
BB
BMAN, let me know on the model, etc.
Old 03-08-2008, 06:17 AM
Speedline sells a set for the 930. My buddy has a set 18x12 and 18x9 I hate him no spacer. The 964 have no big wheel lips which I think make the wheels.
Old 03-08-2008, 01:40 PM
930gt-40r's Avatar
BMAN, did you have to show that picture? Damn those look good!
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-08-2008, 06:26 PM
I think I used 1 inch spacers up front and 1.5 inch in the back.
Call Ernie at Ernies alloys in Miami, he will know.
Old 03-16-2008, 05:49 AM
