rear spacer size original on 930s?
Hello,
which spacer sizes was original on 930s? Are there different sizes over the years? Mine is 87, I have something over 40mm now, is that original? Falk
87 930 bblk/blk 88 3.6 white/blk |
cycling has-been
front = 21mm
rear = 28mm Stoddard lists 1974-87 for the fronts, 1974-89 for the rear the original will have a 930 number on it somewhere Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
+1.
21mm - front 28mm - rear |
A fellow Pelacanite
I thought the front spacers were no longer fitted after 1980?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
I believe that's correct, but then I have a '79 ![]()
2014 Cayman S 2011 Cayenne Turbo 1979 930 (475 rwhp at 0.95 bar) |
cycling has-been
maybe you could get 16's in 7's and 8's as an option through '89?
Bill K
After the next project
spacers
I own an 87-930 with no front spacers as well.
Thread Tools | |
Rate This Thread | |
