Doug Siegel
fuel pressure readings
I just bought a CIS fuel pressure tester. I know how to hook it up but I have no idea what rate of psi increase I am looking for. Can anyone suggest a link that might display a graph? Many Thanks.
88' 930.
Old 03-07-2008, 07:03 PM
Crotchety Old Bastard
RarlyL8's Avatar
Does your WUR part number end in 054 or 112? Probably 054.
I hope it is OK to post this page out of my manual. If not I'll just e-mail it to you. This is from an early 930, your '88 should be similar.
Old 03-07-2008, 07:21 PM
Doug Siegel
Hey Rarly,
I don't know which WUR I have. I'll look tomorrow. Strangely, I wasn't able to get the graph off this page. It would be great if you could email it to me. Thanks. This chart gives temp : bar. Is there anything that depicts time: bar?....how long should it take for the fuel pressure to move and is it in spurts or steady?
Old 03-07-2008, 07:37 PM
RarlyL8's Avatar
It is a steady progression from ~20psi - ~50psi dependant upon temperature.
The time it takes is also dependant upon temperature. The colder the ambient temperature the longer it takes to climb.
You say you experience a jumpy progression. That is not typical. It could be that you have a sticky gage or an air bubble.
Cold start quality is solely dependant upon the fuel pressure and the cold start valve. I think you have eleminated the CSV as an issue.
Check the chart against your pressure and temperature. It needs to be spot on in the middle of the range to give you best results. I have found that even when all parameters are within spec the system will not run optimally until all are near the middle of spec. I believe that phenomenon is due to component age. Precision is required due to reduced tolerances from wear and age.
Once the car starts cold the AAR and mixture adjustment become important.
Old 03-07-2008, 07:57 PM
