Doug Siegel
cold pressure- warm up regulator
I'm testing the fuel pressure for the cold start setting on a Warm up regulator- 88' 930. Anyone have the specs? Thanks...
Old 03-10-2008, 08:20 PM
Send a message via AIM to Chuck Jones
You might give Brian Leask a PM....he makes the adjustable WUR's and is as savy as anyone on the subject.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 03-10-2008, 11:08 PM
Crotchety Old Bastard
RarlyL8's Avatar
The cold pressure scale for the '88 should not be significantly different than that of the earlier cars with the same 054 WUR. The scale slides with temperature.
Old 03-11-2008, 05:59 AM
Macht Schnell
les_garten's Avatar
Hi Brian,
You adjust for the air temp that day, and there is a temp compensating mechanism that adjusts cold pressures later depending on ambient temp? Where does it get it's temp reference?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 03-11-2008, 01:35 PM
RarlyL8's Avatar
The temperature adjustment function is done mechanically with a bi-metal strip referencing ambient temps. Once the cold engine is started an electrical current heats the strip which moves against the diaphragm increasing the fuel pressure as it warms. Once warm the engine heat then keeps the strip maxed out.
You check the cold pressure readings against the chart of ambient temp vs pressure range and adjust to the middle of the range using that one data point reference. Once set the pressure should reamin in spec throughout the cold range. If not the bi-metal strip may be worn out, damaged, or out of alignment.
Old 03-11-2008, 01:51 PM
Macht Schnell
les_garten's Avatar
Is the strip inside the WUR?
Les
Old 03-11-2008, 01:57 PM
RarlyL8's Avatar
Yes
Old 03-11-2008, 02:08 PM
I just sent off my WUR to Brian Leask yesterday to have him make it fully adjustable.
I'm putting together my own RPM activated switch and vacuum solenoid in to make it so I can set what rpm the WUR/control pressure regulator will recieve boost pressure from the throttle body port for boost fuel enrichment.
Since I put in a modified fuel head a couple months ago the midrange is too rich, so hopefully this will remedy that.
Now it's a good time for me to finally install my rennaire R134 AC upgrade kit while the car is down.
Old 03-12-2008, 01:41 PM
DPHANS
DPHANS's Avatar
Hi, Download from my home page. the Bosch CIS work shop manual . 177 meg
(right click to save)
http://www.garagecare.se/
BR
DPHANS
Only Dp 935 cars for me : Dp 935 2.8LTwin Turbo and a Dp 935 Cab 3.0L Twin turbo. Dp 935 3.0L coupe
Visit Youtube= DP935 MANTORP
Old 03-13-2008, 11:49 AM
Macht Schnell
les_garten's Avatar
BR
DPHANS
Hans,
Tackar så mycket !!
I've thought about the fact I didn't have that publication for a while now. It's nice having it in a form I can access from a web interface.
You PIX of the DP's are awesome also.
Old 03-13-2008, 12:57 PM
file damaged ?
cannot download the file ( right click, save as)
each timeget a message "the file is damaged and can not be repaired"
anyone else having this problem ?
thks
Old 04-10-2008, 04:24 AM
Doug Siegel
I downloaded it last week.
Old 04-10-2008, 04:29 AM
