1980 Porsche 930 Turbo
930 fuel pump wiring
Does anyone have a wiring diagram on wiring the pumps to not run when the key is on the on postion. I would like to listen to the radio without the pumps running. The previous owner had the pumps wired with two realys that casused the pumps to run while the key was on the on postion.
Old 03-11-2008, 07:46 PM
930gt-40r's Avatar
Hook them up to a set of relays with a switch? That would work unless you dont like extra switches
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-12-2008, 05:00 AM
Macht Schnell
les_garten's Avatar
Hello,
I would wire my Radio to run without the key. That's how almost all European cars were wired. That's how my Merc and Porsche are wired. I just hit the button on the Radio.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 03-12-2008, 06:59 AM
resident samsquamch
sand_man's Avatar
Just curious, are you sure they were "re-wired"? The reason I ask is that even stock, the fuel pumps were wired with two relays (not counting the other relays/switches in the engine compartment that are in the loop). Can you reach into the engine compartment, around the airbox (reach around from the driver's side) and verify if there is a wire connected here:
When this wire is disconnected, the fuel pumps run when the key is switched over (engine not running).
Just a thought, maybe there's hope that this can be simple...
-jeff
Old 03-12-2008, 09:08 AM
A fellow Pelacanite
NathanUK's Avatar
Surely to get the radio to work you only need the key in the 'Accessory' position, not the 'Ignition / Running' position.
Maybe you need to run a new wire to your radio. It should already have one there, try to find it.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-12-2008, 10:53 AM
resident samsquamch
sand_man's Avatar
That's a good point. Mine is like this.
-jeff
Old 03-12-2008, 11:01 AM
A fellow Pelacanite
NathanUK's Avatar
That should be the way they left the factory. Of course both my cars have no radio
Old 03-15-2008, 05:54 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
