heat exchanger barrel nut stripped
Any ideas on how to remove the barrel nut if the allen part is stripped out? I ended up having two of these. One of the barrel nuts started to turn before it stripped out but it didn't quite make it. Of course they are both on the DS and much harder to get to. Big surprise.
Bill |
OFF THE BOOST PIPE NOW...
You gotta think outside the box with all your tools. Can you get a chisel to it and back it off? Can you fit a tight socket over it, hammer it down and back it off? Can you cut it off with or without the stud?
Any pics of the offending nuts? |
I used a drill with a bit the same diameter as the stud threads. Haven't replaced the stud yet, but I plan to first try removing it with conventional methods (stud remover, heat, etc). If that fails, then I will buy that device that a pelican made and sells for drilling out broken studs.
Maxx 86 Ruf'd and rebuilt (sold) |
use a dremel tool best bet cut at an angle on the barrel .good luck i'm at a stand still because i broke a screw extractor in one
pca 30 year member,1977 porsche turbo body targa 56 vw ragtop oval 01 harley sportster 18 Chevy Colorado diesel BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL |
Thanks everyone. I thought about the chisel. Getting a socket on there is a pretty good idea. I may try that as a next step before tearing it all up with a chisel or drilling. I would like to keep that as a last resort. How about welding a piece of threaded rod in the hole? Anyone tried that?
angelny911 - I have had the worst luck with screw extractors doing exactly what you said. So I don't use them anymore.
Bill |
Wer bremst verliert
Soak it with pb blaster for the next few days. Then weld it to a long, wasted rod or better yet the allen tool that stripped it. The heat from the weld should get it out.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Nut
The socket over the nut is a good idea, but before you try that, heat it up and let it cool a couple of times (propane/mapp gas) then the last time, heat up again slip the socket over while hot and try to loosen. I've had a bunch of these, and heat always worked for me.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
try 12 point allen socket.the type used for c-v joint bolts...heat up nut also
I got one of them today and another regular nut. I ended up using the 8mm allen and welded a couple of weld blobs on it. Then I ground them down to give them a sharp point. I then heated the nut SUPER hot and hammered the allen wrench in the hole. This was a long and drawn out process but it sounds easy in the text. Anyways, I got one of the two. I'll try the other one tomorrow. Then all I'm left with is the 3 regular 13mm nuts on the DS.
The weld blobs are too big for the other nut so I'll have to grind it down so I can hammer it in. Then add weld as it rounds out. Hopefully not and I get it on the first try. Yeah right.....
Bill |
I got the last barrel nut tonight!
![]() Any tips or tricks on the last three of these nuts? Will the nut splitter fit in there after the pipes are removed?
Bill |
we have an old 14" long screw driver with the end sharpened like a chisel we use to split those nuts..don' throw away you old tools use them for some thing else
A fellow Pelacanite
I find these very useful. Irwin makes them.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Thread Tools | |
Rate This Thread | |
