cl8ton's Avatar
Advice on this bolt (Zork + 934 WG)
I have tried all conceivable ways of wrenching this bolt tight, short of flattening the Zork to make room.
The tab is attached to the 934 WG pipe and bolts to the turbo flange.
Brian, you have any advice about this,my current method is a ball peen and a center punch to tighten
Anyone have suggestions on tool mods so it can work?
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 03-13-2008, 09:08 AM
Crows Foot might work to get in there.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 03-13-2008, 09:11 AM
Don't see how you can get a wrench over that being so close to the pipe.
Try taking the stud out and put a bolt in.
If a regular bolt still won't work, then an allen head bolt using a short L shaped allen head wrench.
Old 03-13-2008, 09:59 AM
Crotchety Old Bastard
RarlyL8's Avatar
That nut is a bad one but always doable. It looks like the tube angle on that Zork may be more sever than it's supposed to be.
I have one of those ratchet action open end wrenches that I use for that bolt.
Another option (that I do all the time) is buy a $1 Harbor Freight open end wrench and modify it to fit using a grinder.
A third option is to remove the zork and put a smooth relief (nice word for dent) to make some room. The 321 is very pliable before heat cycling, so if you haven't blown too many flames out of it yet it will still bend easily.
Let me know which method works for you. In the mean time I'll take a look at making a change to give more room in that area so that conventional tools can always be used.
Old 03-13-2008, 10:21 AM
what size is it?..10mm's come in 17,15,and 14 outer sizes..stubby open .snap on
Old 03-13-2008, 12:01 PM
cl8ton's Avatar
Thanks for the tips all!
Will probably have to buy a wrench thats close (snap on?) then dork with it on a grinder.
Rod...
Old 03-13-2008, 12:19 PM
A fellow Pelacanite
NathanUK's Avatar
You could change the nut for a K nut one. A smaller spanner is used to tighten giving more room.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-15-2008, 07:06 AM
purplehaze's Avatar
Or replace it with a hex head one, then use a swivel hex drive.
It's the kind of nut used by Porsche on the 3.2 intake manifolds, or starter, where there's little side room.
Good luck!
Glenn
87' 930TT
Old 03-15-2008, 08:25 AM
A fellow Pelacanite
NathanUK's Avatar
Those barrel nuts are quite long though.
Old 03-15-2008, 08:43 AM
cl8ton's Avatar
Now thats an excellent idea!
Just gave the ole Zork the cop test this morning
Rod...
Old 03-15-2008, 09:08 AM
A fellow Pelacanite
NathanUK's Avatar
cl8ton, did you know your avatar doesn't show up? I just get a red cross.
Old 03-15-2008, 12:29 PM
Take the stud out and use an Allen head bolt
Old 03-15-2008, 01:42 PM
