-   -   I need some advice (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/398047-i-need-some-advice.html)
Frapguy 03-13-2008 10:09 AM
I need some advice
I have a "who knows what it is" wide body Porsche. I know you guys will not like this, but I have a alumin Cadi motor in it. But my problem is that I want to build the car for solo 1 driving conditions. My latest project is trying to figure out if I should weld a 3/16th plate on the bottom of the car under the rockers from front wheel to rear ( my thoughts were to bend the pinch weld on the bottom and weld in a pc that is 8 inch wide?. My pan is in good shape except for on the outer of the bottom rockers, I have some rust. I want to be able to through a jack under the car and not worry about crushing it. Any ideas? My stock jack points are questionable. I could cut it out and weld in new parts, but I am going for more practical than oem. here is some pics. I did put the por 15 on the inside and the floor looks great.
thanks Brianhttp://forums.pelicanparts.com/uploa...1205428058.jpg
http://forums.pelicanparts.com/uploa...1205428093.jpghttp://forums.pelicanparts.com/uploa...1205428561.jpg
http://forums.pelicanparts.com/uploa...1205428584.jpg
