Stranger on the Internet
You California guys should consider water injection. I run it on my turbo SC, and it works great.
Pat
Patrick E. Keefe 78 SC |
Crotchety Old Bastard
The adverse actions of EtOH on the CIS are compounded if your car is not a daily driver.
As stated above, EtOH likes water and is prone to accelerate rusting and gumming which is better tolerated in EFI systems than the precisely machined spaces of a CIS fuel head. It is also more corrosive than toluene based fuels. I drive my car sporadicly. It may get driven every day for a week and then sit for 2 weeks. Sitting gives the water/EtOH a chance to surface react.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Certifiable
I have a station near my home which sells 100 and 110 octane fuel, is it advisable to dilute the high octane fuel with the 91 octane, to achieve a 93 octane consistency? Or is that taboo?
Sean D. 1987 930 India Red/Beige/Black; Mahle 3.4L; Kokeln IC; K27 7200; GHL Headers; Borla Stainless Muffler; SC cams; Sachs Aluminum Clutch; Aluminum flywheel; Bilstein Sport Shocks; Adjustable Rear Sway Bar; Weltmeister Shock Tower Brace; Lowered and Corner Balanced; MOMO RSGT Seats... |
Macht Schnell
That's the way we did it in the old days of Amoco Premium. You also used to be able to mix a little leaded gas in with the unleaded to raise the octane of the unleaded.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Certifiable
Les,
Thank you for the reassurance! I would hate to do something foolish! -Sean
Adrenaline Junkie
Mukilteo by the Sea!
Thread Tools | |
Rate This Thread | |
