Rebuilding 3,0 turbo. WANT MORE POWER...
We are starting to put together a Euro 1977 930 3,0 turbo.
We have a 965 turbo and a K27 already. Car has G50, and no heat exchangers.
ANy suggestions on things we should do to reach 350+ reliable rwhp ?
Old 03-16-2008, 02:05 AM
Crotchety Old Bastard
RarlyL8's Avatar
There are lots of ways to get 350WHP. You can do it with mostly stock parts.
Do you want to do it the expensive way or the less expensive way?
Simple/stock/relatively inexpensive:
- Euro Heat Exchangers
- K27-7200 Turbo
- 965 Intercooler (or like)
- 1.0bar boost
- Thorough Tuning of CIS/Ignition
That will get you close. Head work will put you there or beyond. If you can find a cheap set of used headers all the better.
Old 03-16-2008, 06:01 AM
rsrmike's Avatar
If I were you I would look into raising the compression ratio,
and a set of SC or 964 cams.
The extra comp should help the low end grunt, either turbo you mentioned should be about the same
The cams might make rowing through that G-50 a little more exciting
What gears are in the trans? 1.0 bar may give traction trouble
Rarly L8 brought up the best point of all...
How much $$$$
Old 03-16-2008, 10:13 AM
Adrenaline Junkie
Hayabusa's Avatar
I know!!! My stock US 3.0L couldn't pass a school bus full of kids off the line at present state!
Old 03-16-2008, 01:17 PM
- K27-7200 Turbo
- 1.0bar boost
Ive already got the Turbo and IC. and no heat exchangers at all.but plain headers.
What do you mean by tuning the CIS/Ignition ?
Also, to increase compression do I only have to change the pistons ?
I don't want to spend a fortune, but am prepared to upgrade some stuff"while Iam there" !!!
Old 03-16-2008, 02:32 PM
rsrmike's Avatar
Pistons would be the best way to increase compression. I'm not sure how many options you have short of something custom...
3.0 turbo's are a little weirder than one would think, having a aluminum case but a 2.7 crankshaft...
Anyone know an easy trick? longer rods? machine heads?
Old 03-18-2008, 01:41 PM
RarlyL8's Avatar
If you are truly on a budget and just want the HP numbers leave the engine stock. You can get to 350WHP with bolt-ons. Use the G50 to improve off boost driveability.
By tuning the CIS I mean verifying your A/F ratios. There is a lot of power to be lost if they are not optimal. Cam timing will help as well.
I'm simply thinking of the least expensive way for you to hit your number. Not necessarily the most elegant.
Old 03-18-2008, 02:05 PM
930gt-40r's Avatar
I got a guy with a 930 crank that needs to be refinished if you are interested.
I also have an 86' turbo oil pump if that would make a diffrence.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-18-2008, 06:45 PM
rsrmike's Avatar
3.0 displacement + 6.5?/1 compression + 350WHP = hairy little monster
Should be fun w/G50... Good luck!!
Old 03-19-2008, 12:23 PM
A fellow Pelacanite
NathanUK's Avatar
I've heard the short stroke 3.0 930 especially with it's lighter weight can easily be underestimated
Keep the short stroke and do bolt ons.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-19-2008, 02:34 PM
Max Sluiter
Flieger's Avatar
What is the bore/stroke of a 3.3 liter 930 compared to the 3.0?
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 03-19-2008, 03:24 PM
Adrenaline Junkie
Hayabusa's Avatar
Exclamation
1974-77 Turbo Carrera 3.0L - 1140 (kg) 2508.4 (lbs.), 2994cc @ 95mm x 70.4mm (engine capacity), 260bhp@5500, 343@4000 (max torque), 155 (top speed), 5.5 (0-62mph), 3227 (production numbers)
1978-89 911 Turbo 3.3L - 1300 (kg) 2860.5 (lbs.), 3299cc @ 97mm x 74.4mm (engine capacity), 300bhp@5500, 412@4000(max torque), 162 (top speed), 5.0 (0-62mph), 17,425 production numbers)
Old 03-20-2008, 10:16 AM
Max Sluiter
Flieger's Avatar
Thank you! :-)
911S
Old 03-20-2008, 02:17 PM
Me like track days
Craig 930 RS's Avatar
A 3.0? You'll achieve a maximum of about 320 RWHP on a dynojet with a 3.0.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-20-2008, 06:15 PM
lite75's Avatar
2nd RSR mike, add 964 cams and 7.5:1 compression. The 3.0 with a G50 is a great setup!
75 930, 76 930, 83 SC EFI turbo
Old 03-21-2008, 04:04 PM
Actually, what people like to do with the 3.0 is slip in 3.2 pistons/cylinders like the 3.2 carrera. This gives you the same approximate grunt of the 3.3 if you adjust the compression to 7.5 to 1 or so. I believe it is a direct fit pretty much.
And the short stroke crank will scream to redline with a ferocity that these 3.3 just don't have with the longer crank.
The g-50 gearing will absolutely burn your tires up (in a good way).
I have a 3.0 with a lightweight valve train and I can spin my tires with ease at 70 mph when shifting to 3rd gear.
Keeping your short crank makes your engine unique with the 3.2 pistons. A guy named Pete did it around here and he loves it.
Old 03-22-2008, 09:48 AM
Turbo Hooligan
Big Bore, Short Stroke, and lots of boost with 7.5:1 comp. mines a 3.2 with mahle p's/c's and its like a light switch on and off boost, sooo much fun, its like a 2 stroke 500cc GP bike with four wheels. 400+ hp is very doable though
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 03-22-2008, 01:06 PM
A fellow Pelacanite
NathanUK's Avatar
And to think that Audi build their engines with a long stroke on purpose for economy!
Old 03-23-2008, 02:33 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
