Brando
quattrorunner's Avatar
final details for the swap
OK so most have said it's not a day job to bolt on the 930 fuel and exhaust parts to a sc. Other than figuring out the feed and drain issue from the turbo, The question I have is the distrbutor detail to retard? Do I need to have it recurved or is simply retarding it's posistion good enough? I have a Tial with a small green spring. I do need the muffler still and a couple other things, but it still doesn't seem to be a difficult thing.
The big question I have is if I got quicker spooling turbo, will it be a problem if I keep the boost in check with the stock 79sc internals?
Anyone have anyother things I'm not thinking of right now?
Thanks, BA
Turbo powa!
1977 911s. it's cool
Old 03-18-2008, 07:27 AM
Brando
comon punks
Turbo powa!
Old 03-18-2008, 11:54 AM
Crotchety Old Bastard
RarlyL8's Avatar
The early 930 distributor does not retard on boost so you should be OK to just set the advance accordingly on your SC unit (dependent upon C/R). Ben has an SC dizzy on his turbocharged engine and may be more help.
I can help you with the muffler
The turbo should match the low boost parameter. THe SC turbo guys need to chime in on the particulars.
Old 03-18-2008, 12:31 PM
Stranger on the Internet
patkeefe's Avatar
A quicker spooling-than-what-turbo?
I run the stock SC distributor in mine, maybe at about 28 degrees total advance. Seems fine. If I retard it, the car is a dog off boost. Maybe someday I will recurve it. I suggest running yours as-is for a bit and see how it works.
Patrick E. Keefe
78 SC
Old 03-18-2008, 02:53 PM
Brando
For now I have a k26
Turbo powa!
Old 03-18-2008, 05:05 PM
patkeefe's Avatar
Here's what I have...
Rajay T04 in "V" trim. Makes good power, even though I'm down in the bottom of the center island at 6 PSI boost.. Check the Garrett maps, as there may be something a bit more efficient. I can get away with some more boost pressure in mine.
This may be a K26 map, not sure what trim...I would think that K26 would be about as a quick spool as you would want
Patrick E. Keefe
78 SC
Old 03-18-2008, 06:14 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
