-   -   Question re "Overboost Switch" (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/399148-question-re-overboost-switch.html)
Emission 03-19-2008 08:33 AM
My engine has been cutting out on hard right turns... and then it runs normally when I straighten the car out again. :confused:
I think I may have found the problem. After poking around with a flashlight last night, I noticed the "overboost switch" wire had vibrated loose. The wire has a rubber housing, so it was kept in loose contact with the switch. I assume right turns pulled on the wire and it broke contact... and when I went straight contact was again made.
My questions:
Will the engine die if the overboost switch is disconnected?
What does the overboost switch kill (fuel or ignition)?
Cowtown10 03-19-2008 09:15 AM
I might stand to be corrected but I was having similar troubles which affected the fuel not the ignition, I had the switch replaced but the mechanic mentioned that you could just ground it to disable the switch however leaving your engine vunerable.
Emission 03-19-2008 09:21 AM
I think you are answering my question in a roundabout way... :)
You are saying the switch must be connected or grounded. If so, then I have found my engine cut-out problem. If the switch can be left completely disconnected and the engine still runs, I have to continue searching.
You don't want to disable the switch.
Cowtown10 03-19-2008 09:51 AM
The Germans are efficient (being one of them) if you didnt need it, it wouldnt be there, my opinion. The last thing that I want or could afford is grenading my engine and having to replace it.
Off topic but how do you like your fabspeed? I just bolted up the single outlet with air intakes and a 1 bar spring...it should be on the street tonite
sand_man 03-19-2008 10:14 AM
Originally Posted by Emission (Post 3837218)
My questions:
Will the engine die if the overboost switch is disconnected? YES
What does the overboost switch kill (fuel or ignition)? FUEL
Answers...
Cowtown10 03-19-2008 10:19 AM
Sandman,
Disconnect and disabled are two different thngs. Am I correct that if it is disabled the car will still be operational but vunerable to damage?
sand_man 03-19-2008 10:23 AM
The car is not operational, UNLESS you have grounded the wire that once connected the switch. The fuel pumps won't run. I know this because whenever I remove my 965 intercooler, which has the overboost switch on the actual intercooler, I can't run my fuel pumps (to check fuel pressures for example) unless I ground that wire.
Cowtown10 03-19-2008 10:26 AM
Gotcha, so i was correct...As Emission said I answered his questions but in a round about way.
Have patience I am new and trying to learn these cars!! Thanks
sand_man 03-19-2008 10:29 AM
As for actually disabling the switch, I think it's set to cut the fuel pumps at 1.2 bar (from what I recall...might be wrong about this number), and I've seen a few threads where people have tripped it. So I guess it can be thought of as a good safe gaurd. However, if it really is 1.2 bar, I'm not sure if the damage is already done???!!!
Cowtown10 03-19-2008 10:33 AM
running naked through a mine field...dont want to take the chance or find out.
I just had a 1bar spring installed. Pros and Cons??
Emission 03-19-2008 10:37 AM
I think it is 1.3 bar... and mine tripped when my wastegate diaphragm ripped open a few years back. It is an excellent safeguard that you don't want to disable.
Emission 03-19-2008 10:38 AM
I like it. I'll send you a PM tonight when I have more time to write... :)
- Mike
Shadetree930 03-19-2008 11:24 AM
There is another thread from a couple of days ago (Name this part ....)
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/398655-name-part-its-function-win.html
that was talking about the overboost relay. Is that the same as the switch?
If not, do you have pics of the switch?
911boost 03-19-2008 01:33 PM
When I got my car the switch was disabled, grounded to the same connection on the intercoler as the intercooler ground. My wastegate had 1.1 bar worth of springs in it, so I am guessing that the previsous owner got tired of the fuel pumps shutting down.
I went down to .8 bar in the wastegate, and continued to have problems with the overboost. I even installed a new switch. I hate the location that it is in with regards to the 965 intercooler. I agree with teh folks that have moved their switch closer to the intake. Since I have had off and on issues with mine, I may do this as well.
Bill
sand_man 03-19-2008 02:32 PM
I have a .80 bar spring in my Tial, and I have the mods to rock a 1.0 bar spring, but...
911boost 03-19-2008 02:34 PM
I am with you 100% sand_man. Not to mention when I had all the springs in the Tial, the car was REALLY fast, and I am sure I would have lost my drivers lic.
Bill
Emission 03-19-2008 03:21 PM
I took out my 1.0 bar spring and put the .8 bar spring back in...
NathanUK 03-19-2008 03:49 PM
Depends on what turbo, IC and fuel you are running.
Cowtown10 03-19-2008 08:29 PM
Nathan,
I am running a stock IC and turbo and min 95 octane.
Emission 03-19-2008 09:49 PM
I should add that I dropped down to a stock spring only because California's gas sucks (only 91 octane), and I was getting predetonation. :mad: With stock boost, I don't have the issue. If you can get better gas, and your mixture is rich enough, I wouldn't worry about 1 bar.
