1980 Porsche 930 Turbo
WUR Question
Can anyone tell me how how to wire in my WUR. The current connection is not getting power. Also feedback on Brain Leask adjustable Wur. Is it worth the investment.
A fellow Pelacanite
AFAIK the WUR should only get power while one of the fuel pumps are energised. This is so it can only heat up while the engine is actually being cranked or running.
If your car is modified in any way then the BL WUR will be of benefit to you, especially if you have a excellent wideband AFR setup. You can then attempt to tune out rich or lean areas.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Thread Tools | |
Rate This Thread | |
