87 930 Shock Replacement
I just took out the strut out and put it back in after i replaced the ball joint. I noticed that passenger side is very low and there were some reddish fluid. I think i lost my shock. Could taking the strut assembly out and put it back in a reason to ruin it. Anyone replaced their shocks? Pictures are appreciated. Thanks!
MJ
Houston, TX
Old 03-23-2008, 08:05 PM
mark '87 930's Avatar
I sincerely don't think that removing and re-installing your strut made the unit leak. Barring of course a strenuous uninstall process with lots of twisting and jarring!! A simple removal and re-installation is not 'stressful' for the shock.
I don't have pictures for you, sorry, but I'm sure there are tons here on this site.
I replaced mine when I bought the car.. more to baseline the car as I didn't have all the service records. I also did it for ****s and giggles as I absolutely love to work on my car. It's a simple process really if you are reasonable handy with a wrench.
I think I paid something like $450 for a set of four shocks (two inserts for the front, and shock towers for the rear). I put in the sports all around while I was at it.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-26-2008, 02:47 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Didn't they used to pour some oil in the strut to transfer heat? Could that be your source of red oil?
Old 03-27-2008, 04:43 PM
DW SD's Avatar
Yes! common practice. Oil or antifreeze is sometimes used.
Doug
1971 RSR - interpretation
Old 03-28-2008, 03:44 PM
Macht Schnell
les_garten's Avatar
Hello,
Seems the thread is almost done and I have a shock question. What is the difference between Bilstein HD struts and Sport struts.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 03-28-2008, 04:03 PM
DW SD's Avatar
Originally Posted by les_garten View Post
Hello,
Les
Les,
in a word, valving. The latter has stronger damping characteristics. Mass, spring rates and damping all must work together to have an appropriately tuned suspension.
Old 03-28-2008, 04:50 PM
