best tubing to use for vacumn/boost lines?
l`ve been tweaking things on my turbo system and l`m not happy with the combination of tubings l`ve used to plumb my wastegate,blow-off valve and FMU,etc. l found that motorcycle fuel line looks good and seems to be resistant to expansion so l have tried that. The best thing l think l`ve found is Japanese car rubber vacumn line with the colored braiding on the outside. l`ve had to scrounge this from the autowrecker and to do it right l need more of it. l guess l`m concerned about heat and what it does to the signals with silicon lines so l don`t use any silicon. My latest purchase is what appears to be PVC tubing and if l can secure/seal the ends l think it won`t expand at all. Anyone have any input on all this? what`s everyone else using? line expansion may be something not worth worrying about..
my life begins at 150MPH
Old 03-27-2008, 09:42 AM
930gt-40r's Avatar
I use a combination of -4 AN lines and silicon lines. I use the silicon for the Fuel pressure regulator and the map sensor. For the wastegate and blow off I use -4 an stainless braided line.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-27-2008, 06:44 PM
the braided line seems like a really good move
Old 03-27-2008, 08:30 PM
I used -6 ss braided line and AN fittings for the WG.
I went with 6 because I had that left over from doing the fuel lines
Old 03-28-2008, 03:56 AM
thsnks Jerry. Man your car looks incredible,almost exact spec as mine on the turbo system too.Why sell it?
Old 03-28-2008, 10:13 AM
Send a message via AIM to Ag02M5
http://www.germansupply.com/home/customer/product.php?productid=16341&cat=&page=1
I ordered this. Looks as good or better than stock.
RT
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 03-28-2008, 10:18 AM
Why sell it?
good question, I'm insane and have a serious car problem
edit,,, serious addiction issues
Old 03-28-2008, 10:51 AM
BoxxerSix's Avatar
Any hardcore race build I do here I use braided lines and AN fittings. If weight is a huge deal, or the build is a moderate to aggressive street build I like using double ply braided EFI fuel line. Very similar to line like Aeroquip uses for the push lock fittings(just a lot cheaper by the foot) and is quite acceptable in terms of durability and looks.
Adam Hennessy
Old 03-28-2008, 12:47 PM
thanks guys,all good ideas. Since l`m out in the high desert country it`s all mail order,no hose/fittings stores around so research is everything.
Old 03-30-2008, 08:45 AM
David's Avatar
I used silicone vacuum hose, the stuff that's red or blue. It looks nice, but it splits too easily when taking it on and off so I don't recommend it.
2014 Cayman S
2011 Cayenne Turbo
Old 03-30-2008, 09:12 AM
Fuel line works fine, and it's cheap.
The best would be what you find in an aircraft or race car... $$ Aeroquip stainless braided for pressure, heat, oil/gas tolerance, and abrasion resistance.
Kevlar braided is even more expensive.
Old 03-30-2008, 11:07 AM
Forced Induction Junkie
WERK I's Avatar
+1
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-30-2008, 12:15 PM
