935TURBO's Avatar
I need some help for sway bars......
Hi Turbomen,
I just got this and have no schematics support for the fitting......rears are OK...but I think I will have some mods to do for the front...isn't it...?......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 03-18-2008, 01:22 PM
cl8ton's Avatar
Serge, I have those exact TRG sway bars on my 930.
Here is a LF corner showing orientation, if you need more pics let me know.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 03-18-2008, 01:29 PM
935TURBO's Avatar
Thanks very much Cl8ton...yes that's exactly that one....but that mean I'll have to make 2 holes in the front body for the bar....of course, I'm very interested in getting pics...I'll send you MP with my mail...Thanks....
Old 03-18-2008, 02:13 PM
rsrfan's Avatar
Serge,
there are many excellent threads in the tech forum detailing the installation of through the body sways and where exactly to drill the holes. Additionally, since you like to weld, you may want to reinforce the holes at that time.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 03-18-2008, 03:37 PM
rsrfan's Avatar
Tarrett - Elephant Racing Sway Bar Installation Info
Where To Drill Hole For Front Adj Sways
JP
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 03-18-2008, 03:43 PM
935TURBO's Avatar
Thanks JP....very intereting....and of course, very important...the reinforcement....absolute priority.......
Old 03-18-2008, 04:52 PM
930gt-40r's Avatar
I am soooo happy that 935TURBO posted this because I have the same issue with my 930
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 03-18-2008, 07:33 PM
Me like track days
Craig 930 RS's Avatar
Reinforced rear mounts are a must or don't do this sway setup -
I recommend WEVO console sway rear mounts.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-18-2008, 07:58 PM
Smart quod bastardus
fredmeister's Avatar
WEVO rear mounts are a must as well.
Once you go larger rear sway bar the stock mounts will break.....and leave you with broken rear sways at your next track day!
Call TRG where you got the sway bars and tell them to send you the installation instructions for the front units.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-19-2008, 08:36 AM
935TURBO's Avatar
Problem.....with the rear......Am I doing a mistake.....?
The bar is too close to that plate/support......is it normal...?.....if so, no problem, I'll make a little bracket.......did someone have the same problem...?
Old 03-24-2008, 01:54 PM
GJF GJF is online now
Slantnose from HELL
GJF's Avatar
You can do 1 or 2 things.
1) You can add shims under the mounting blocks. Possibly 10mm - 13mm
2) Clearence the transaxle front mount
And as Craig and Fred stated, reinforced rear swaybar mounts ARE a MUSTwith performance swaybars. The WEVO mountes are very nice pieces and make the task easy instead of making custom reinforced brackets.
It changes from time to time.....
Old 03-24-2008, 03:05 PM
935TURBO's Avatar
Thanks for the info GJF....I saw what Craig and Fred said...but didn't understand completely why.....so, is that what they/you mean.....
http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-RARBConsoles.htm
If so, it has to be machined and need some Nylon or Teflon rings.....?
Old 03-24-2008, 03:26 PM
935TURBO's Avatar
Does someone made this upgrade with the WEVO mounts...?....pics...?......
Thanks.
Old 03-24-2008, 03:41 PM
Slantnose from HELL
GJF's Avatar
no... you cut off your existing rear swaybar mounts and weld the WEVO units in ther place. They provide a new mount for your swaybar. You will simply bolt the new swaybar to these after they are welded in place.
Old 03-24-2008, 03:43 PM
Slantnose from HELL
GJF's Avatar
Old 03-24-2008, 03:52 PM
Welded the wevo mount about 20mm more rearward/up than the original mount, to clear the gearbox plate.
Old 03-24-2008, 04:02 PM
935TURBO's Avatar
Thanks a lot guys.....so I have to ask for a quotation with the shipping to FRANCE....and how long for the delivery...?....
Old 03-24-2008, 04:06 PM
I needed to make shims to clear the tranny mount bracket as well. The stock rear sway bar came with a bend in the middle of it for this very reason.
Be careful on the passenger side because welding around the fuel pump there could be dangerous. The second turbo fuel pump is mounted up in this area of the car.
Old 03-24-2008, 05:42 PM
I believe the TRG bars came with a shim because later cars need them to. I fabricated one for mine as well.
On the Wevo mount, one question/comment - buddy of mine had upgraded his sway bar mount. The mount held up (its now Wevo), but the weak part after this "upgrade" was the sheet metal! The mount and bar actually started tearing the sheet metal off the car so he had to weld & reinforce the whole area. Anyone had experienced this?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 03-25-2008, 06:27 AM
A fellow Pelacanite
NathanUK's Avatar
The advantage of the Wevo is not just that the part itself is strong but due to its size it spreads the load further on the bodywork.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-25-2008, 02:04 PM
