Blitzkrieg
jly535's Avatar
So whats the best RADAR DETECTOR???
I got a $206 speeding ticket today, so its probably wise for me to invest in one soon if I want to keep my license, this will be my first summer with 930 and I like my spirited drives in the mountains. Jamie
Old 04-02-2008, 06:44 PM
i heard valentines are good...i think i need one too
1979 930 Euro
50k:Lindren Green:B&B Dual Out Pipes:K27:965 I/C: --SOLD!!
Old 04-02-2008, 06:51 PM
Me like track days
Craig 930 RS's Avatar
Valentine 1, hands down -- don't waste your time with anything else no matter how gadgety and appealing the GPS crap looks on the Escort -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-02-2008, 07:14 PM
F350Lawman's Avatar
Passport 9500i is IMHO the best system out there. It is just about as sensitive as the Valentine w/o all the false alarms. Most of us travel the same routes often. With the 9500 you travel the route once, program out the false alarms with the GPS feature it memorizes the exact position and frequency and it doen't alarm next time. If the frequency or position is slightly diff. it knows and you get the warning you need. With the others you get false alarms, so you start to delay braking or worse ignore them and BAM yer' busted. You can also use the GPS to mark speed traps, red light cameras etc.
Sure the Valentine gives you the litlle arrows, but who cares where the signal is coming from if you don't even know it's real....when the 9500i goes off, hit the brakes..it's REAL! You also get very good warnings around corners and over hills.
No.... I don't work for Passport but I am a retired LEO and now I travel about 75 -100K miles a year on business at high speed and the Passport is close to 100% for radar. My business partner is a retired Trooper and also swears by and uses the 9500i. It saves us some very embarrassing moments.
Now for laser they are all 'iffy". They do alert sometimes but warning time is next to zero unless you happen to get some light bounced off another vehicle before they aim at yours. Once they hit you it's pretty tough. If they aim where their supposed to, it may never trigger the detector way up on your windshield. Luckily you can't use laser on the move, need a clear line of sight, it's more of a a pain for LEOs to use, and there are 10x more radar sets out there.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 04-02-2008, 08:25 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
I stand behind Valentine, awesome unit.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-03-2008, 05:04 PM
wcc wcc is offline
wcc's Avatar
Read this, but NOW I'm sold on the Escort. I don't even have the unit that has the GPS but that WILL be my next unit. V1? Nah, maybe I go against the grain.......
Sorry, forgot the link: Radar Detector Suggestions
Bill
Old 04-03-2008, 05:10 PM
Macht Schnell
les_garten's Avatar
Hello,
I have a Valentine 1. Couple of things that make it great to me.
1) The arrows, it really helps to know where the radar is coming from. Also, if it's a False alarm, it is "most" likely a stationary source and you can watch the arrows track it as you go by.
2) For a small fee you can get your V-1 updated every year or so, if new software comes out for it. You send it in, and they send it back QUICK. I've done this twice already.
3) Valentines have Classic good looks, a la Porsche! You can't tell a Ten or fifteen year Old V-1 from a brand new one! The only diff is the SW load, and that is rectified for about $50.
I can't stress how handy the arrows are. You hear a warning go off and you know where to look, you don't look like a Bobble-head trying to figure out:
Which way did he go! Which way did he go!
Laser, you are pretty much Frak'd no matter what you buy. Pull over when the buzzer sounds and get your wallet out.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 04-03-2008, 05:21 PM
Blitzkrieg
jly535's Avatar
Looks like the consensus is Valentine1
But I will compare with the passport, price probably being the deciding factor. Thanx, Jamie
Old 04-03-2008, 05:26 PM
Macht Schnell
les_garten's Avatar
Make sure your Detector is not run from Batteries. The tests I've seen show that they are pretty bad after just a few minutes of battery useage.
Old 04-03-2008, 05:40 PM
Me like track days
V1
Old 04-03-2008, 07:12 PM
F350Lawman's Avatar
They both will give great coverage. The real diff. between these and the cheapo brands are that they see over hills and around corners by picking up bounced signals. When I first upgraded, I put my el-cheappo on the dash next to my 9500i and had my friend run radar while I approached. On a straight the el-cheappo was fine, but put a little bend or dip in the road and the el-cheappo was toast where the high end units gave plenty of warning.
Although I really prefer the 9500i, either one is a great unit. The basic difference is arrows vs. less false alarms. I think the V-1 guys love the arrows because they need visual confirmation that it's not a false alarm, where I travel the same route often and have programmed out 95% of the falsies so
I just stand on the brakes. The V-1 has the big clunky retro look if you want to pretend that you where going so fast you went back in time...(Back to the Future style) or maybe you want to break out yer' Members Only jacket and cruise in your 1987 930 pretending it' is 1987 and your 20 years old again...like I do. The 9500i is more compact on the windshield if you want to be less obvious but looks really weren't a consideration either way for me. I was offered a tryout from a friend who owns a car stereo shop and after my "unofficial and unsanctioned radar test" kept it.
Since then I have bought 2 for others as Christmas presents and now my wife wants one
Old 04-03-2008, 08:12 PM
ZLP ZLP is offline
Low Speed, High Drag
ZLP's Avatar
V1
Old 04-03-2008, 09:22 PM
Macht Schnell
les_garten's Avatar
Heh!
The "Classic look" comment I made was somewhat tongue in cheek and somewhat not. The point I was trying to get across is that if you bought a new V1 when they came out in 1992 like I did, that you can still be using it today some 16 years later with the most current technology in the detector. Just upgrade it every couple years. i've done mine twice. Probably could use it again, this thread has reminded me that I should see what benefits I would get with a new upgrade. If you read some of these threads referenced from this one, you'll note a lot of folks have had a lot of different detectors. Some of these poor guys have had every detector I've ever heard of. Hmmm, why is that???
The kewl thing about the V1 is that it is the only product that has ever promised upgradeability and delivered on the promise. Everybody gets a computer and they are promised you can upgrade in the future. But they never work out that way.
With the V1 you don't buy into obsolescence. You run your Serial number ever couple of years and look at what the upgrade will do for you and decide if you want to upgrade now or wait for the next cycle.
The concept of keeping something and upgrading it every couple of years for performance shouldn't be a foreign concept to anyone here...
It's a good solid product that works well. If you have to have the newest bell or whistle or LED color, it may not be the best bet. If you enjoy always buying new Bells, New Whistles, and New LED colors, it may not be the best bet. It is kinda stodgy and dated looking, kinda like the car it is riding in !!
Old 04-03-2008, 09:39 PM
F350Lawman's Avatar
No, I see how the look could be good w/ our cars...I kind of like the retro look.
As far as getting obsolete, the 9500i has a mini usb port, so the rumor is you may soon be able to download upgrades or possibly gps coordinates of known speedtraps. This way you can get a warning just as if you "marked" in the location yourself as I now do. It works great for laser locations, POP radar spots, etc.
So far nothing concrete on future upgrades, but that port does open up a lot of possibilites, we'll see.
Old 04-04-2008, 07:26 AM
Blackbird Pilot
Reaper930's Avatar
V1
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 04-04-2008, 07:54 AM
juicersr's Avatar
V1. I swear it has saved me time and again from $$$$$$$$$$$$$ in tix, insurance and probably having my licenense revoked. Thing is a miniature AWAC, and i do like the arrows.
Anyone know about 'Radar Jammers" like this, sold by one of the board members...
http://www.needfultoyz.com/Blinder_Laser_Jammers_s/62.htm
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 04-04-2008, 09:35 AM
juicersr's Avatar
Well, not sure why the 'embed' of the youtube video didnt work, but you can see a demonstation of the LASER (sorry, not Rader) jammer on the link
'79 930/934 replica
Old 04-04-2008, 09:37 AM
juicersr's Avatar
Direct link to laser jammer vid
http://uk.youtube.com/watch?v=1m_Ta_pJJyE&feature=related
'79 930/934 replica
Old 04-04-2008, 09:41 AM
Me like track days
They definitely 'work' well - objectively speaking. $$$ -
Also, laser is a killer to us as it does not spread out as radar does - it is much more lethal than instant on radar -
Old 04-04-2008, 09:45 AM
F350Lawman's Avatar
From the Blinder video: The average officer writes 15 tickets a day"
Nice scare tactics...I call BS on this. 15 tickets a day?? Let's hope that never becomes the average total. That's more like the 2 week total for your average patrol guy. That is a month total for a guy who actually looks for REAL criminals , instead of wasting time writing soccer moms. Even Troopers or Highway guys write way less than that.... that is 2 tickets an hour, no freakin' way. There may be a few losers running around who write 15 tickets a day...they're the same guys whose lockers are in the corner and eat by themselves. Reckless drivers, drunks, passing school buses, write them all. The problem is there are too many guys who don't know that warn and admonish IS also traffic enforcement. Nothing ticks me more than someone writing a guy/gal on the way home from work or off to little league 5 miles from their house for minor stuff. RANT OFF
But, no matter what the real average is, the laser issue is still a pain. I don't know about buying the Blinder, if they exaggerate so much in their opening line, how honest are they about their level of performance?? I might however consider adding the Escort ZR3 to my 9500i . The only thing that sux is that it can't be transferred (easily)from vehicle to vehicle. $400 for the 9500 and another 350 fro the ZR3 gets pricey to add to multiple vehicles. If anything, just the 930 will get the ZR3
Anyone have any experience with the anit-laser coating??? In theory it sounds plausible to diffuse the laser.
http://www.buyradardetectors.com/products/veil/laser-veil.aspx
Old 04-04-2008, 11:32 AM
