Question cdi replacements
does anyone tried something besides bosch or permatune for a cdi.
mine burn out at 2 yr intervals, grounds are all good.
or has anyone tried trigger fired coils and gotten rid of the distibutor.
do you need a computer box to accomplish this? thanks
Old 04-04-2008, 03:38 PM
Macht Schnell
les_garten's Avatar
No offense intended. I see that this is your first post. As you might imagine, this is covered in some detail here and on the 911 Technical forum. You will notice above that there is a TAB called search. You would do yourself a big service by banging away on it first.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 04-04-2008, 03:52 PM
A fellow Pelacanite
NathanUK's Avatar
Welcome to the board.
Do a search for MSD.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-05-2008, 12:29 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
