Banned
More Turbo Option ????'s
Hello all - thanks to advice given by members of this forum, I'm fairly certain that I am going to purchase a new turbo for my 1987 930 rather that get the stock 3ldz rebuilt (I am currently overhauling the engine - keeping it mostly stock save for Racewear hardware) . . . I have been in contact with Kevin of "Ultimate" with regard to options and pricing and such . . .
My question for all of you: given my goals (reliable but perhaps a little more powerful than stock . . . daily driver with occasional track-day use at Motorsport Ranch, Cresson TX - were I am a founding member) what turbo would you recommend (K27-7200)? What is the performance difference between the K27-7200 and the High Flow variety (the price of the high flow is MUCH greater)? Given the FORTUNE I am dropping on the 24K engine overhaul, the price for the 7200 seems good for me!
As I mentioned earlier, mostly stock with the exception of hardware and muffler . . .
Thanks!
Ronnie
Old 04-07-2008, 04:23 PM
David's Avatar
Kevin should steer you right with what you want to do. If you're losing traction on the slippery slope to big hp (and the higher powerband that comes with it) you could get something else, but if you just want a good reliable, more modern replacement for the 3LDZ, the 7200 sounds like the way to go.
2014 Cayman S
2011 Cayenne Turbo
Old 04-07-2008, 05:04 PM
As I understand it, the K27/7200 is very similar to the 3DLZ, just marginally better.
My $0.02? SC cams for a balance between off-boost response and better/more top-end (you get both), and a K27/HF. Much faster spool, way more mid-range and more top-end. More power, but no big step.
However, Kevin doesn't do the HF anymore, so it's a choice between the S and the HFS.
I figure that the S will spool faster, but not develop as much power up top, the HFS would take a little more to spool but just keep on going at the top.
With a 4-speed and primarily street driving, I'd guess that the S might be a good selection.
with a 5-speed, the HFS would be a shoo-in, I think.
'77 S with '78 930 power and a few other things.
Old 04-08-2008, 11:27 AM
Some folks are using the Garrett turbos. I don't know much about them, but they're an alternative.
Old 04-08-2008, 12:25 PM
David's Avatar
There is a Garrett being made that's a bolt on but I forget who's selling it. I just don't believe they have the quality of the KKK turbos.
2014 Cayman S
2011 Cayenne Turbo
Old 04-08-2008, 01:38 PM
Me like track days
Craig 930 RS's Avatar
24k so far? I'd get the K27 HFS from Kevin and you will be quite happy with it. I am -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-08-2008, 03:17 PM
Banned
Ha, Craig . . .by 24k I meant "24 karat gold" (as in "perfect") . . . an expression that one of my friends uses to describe my "projects" (poking a little fun at my "analness" as well) !!!
Thanks for the responces thus far . . .
Ronnie
Old 04-08-2008, 04:33 PM
Non User
infraredcalvin's Avatar
If you are planning on running mostly stock, go with a true bolt in application. There is no sense in having to fab anything if your performance goals are near stock.
I have a new Kokeln turbo that I'm very happy with. It was truly a bolt on application as I believe the K27/7200 is. I know some here don't like the Kokeln, but you need to know your HP goals and choose accordingly.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 04-09-2008, 08:32 PM
Banned
I'm going to look into the Kokeln option - I passed on the eBay auction due to your comments on my post regarding it (Infafredcalvin) - thanks !!!
Ronnie
Old 04-11-2008, 06:49 PM
Non User
Ronnie
Where are you located? I'm in Southern California, my mechanic is the guy who started Kokeln, he's a great guy (but expensive as he$$ to have work on your car- but he does everything the same way I would - the right way), anyway he actually started to steer me towards the K27 just because it was the "name brand" that most people talk about, after we talked and I explained my ultimate hp goals he set me up with the Kokeln. It's set up real nice right now, the only thing is that you could hear the original KKK spool up, this one I haven't been able to hear - although that could be a result of my stock exhaust.
Let me know if you want more info... I'm glad you didn't get stuck with that ebay frankenstein turbo...
'71 914 track car
Old 04-11-2008, 09:51 PM
Banned
I live in the Dallas, TX area . . . I haven't contacted Vision yet but have browsed their website . . . I am curious to hear what you paid for your kit (PM me if you like) . . . what did you tell them was your HP goal ?
Ronnie
Old 04-12-2008, 07:19 AM
Non User
PM Sent
'71 914 track car
Old 04-12-2008, 08:11 AM
Porschephd's Avatar
Actually this is a little off. The 7200 or the K27S will run 1.5 seconds faster through the 2-6K RPM band over the 3LDZ and will add on average 38HP. They are not even close to being like a 3LDZ.
Stephen
94 3.6Turbo 6-speed AWD
Old 04-12-2008, 04:42 PM
Send a message via AIM to Chuck Jones
Way to go PhD....keep the facts straight.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 04-12-2008, 06:41 PM
