Weld-in sway bar mounts
This will be my first full "season" in the 930- which has stock suspension. I'll be attending DE's and hopefully occasional track days making my road to track ratio about 70/30. I was wondering how critical or necessary to have weld-in sway mounts? Is it really that easy to tear/pull out the stock mounts?
Jay '86 930 '60 Land Rover Series II SWB |
Stock suspension, you should be fine. I would get under there and inspect them for cracks but I'd be surprised if they aren't fine. I wouldn't do the upgraded mounts. However, if you upgrade to a thicker sway bar I would, for sure, upgrade the mounts. I wouldn't say it's an easy job to replace the stock mounts. I do a ton of stuff myself but I wouldn't trust my weld job on this project. So I would take it to a welding shop with my new sway and have them grind off the old mounts and weld in the new mounts so my new sway bar is mounted in the middle of adjustment. It may have to be moved up or down just a touch to clear. Sorry, I went off on a tangent there.....
Bill |
Me like track days
+ Uno
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Skunk works
i broke a sway bar mount on my 76, but i think it was from 30 years of wear and tear rahter than a day a the track
as bill said, if you are upgrading suspension or if they are cracking then upgrade the mounts. The WEVO kit is nice JV
964 RS-4 |
Thanks guys. I'm thinking I may need to increase torsion bar size- and maybe sway bars. Reason being- I'm waiting to receive some wheels from Mike Lindsey- 9's and 11's and I'll be putting 315's on the rear and lowering the 930 so that clearances are pretty tight, much like Jim Culp and others have done. I'm afraid that, with stock suspension, the car may squat under hard acceleration and the tires will rub. So the wheels are causing the domino affect- leading to suspension mods to keep the car from squatting. In the end it should all make the car handle better I suspect with better grip, cornering, etc.
take a look at your fuel pump mount. the mount on my 79 was welded to the left sway bar mount. It was a pain to cut it out and then re-weld the fuel pump mount. My sway bar mount was fine but i added a new sway bar so i had to beef it up. If you look at the stock mounts they are pretty flimsy.
Current: 02 996 C2 6-speed 84 911 roadster race car on track by 11-11 Past:79 930 EFI |
Yes, you can weld the new mounts where the old mounts were. BTW, sway bars control body roll and have nothing to do with squating.
To minimize squating increase the rear TB diameter, and if you do that need to increase the front ones too. Enjoy your new wheels and rubber patch! |
Thread Tools | |
Rate This Thread | |
