9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Oil cooler question
Just picked up a new front oil cooler,, My old one got trashed due to an odd curb or two LOL.. So was thinking has anyone put there's in place of the front A/C condensor ?? It seems to be a logical place, it's protected and there's a fan there I could use. Comments ?
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 04-12-2008, 10:03 AM
Infidel
JBL930's Avatar
Give me a few days and i'll post pics, i'm in the middle of what you're describing, i want to keep it looking stock and this is the way forward, it's a given
Old 04-12-2008, 07:39 PM
9dreizig's Avatar
I"m still torn on weather I give up my A/C long term or not.. I put it back in front ( I've got the front spoiler for it)
"Todd"
Old 04-12-2008, 07:48 PM
Infidel
JBL930's Avatar
My cooler went in today, replaces the front AC rad as mentioned, they hooked up a thermo switch so it'll run the fan when needed. Looks quite neat, i'll get the specs of the cooler and lines for you if you're interested
Old 04-14-2008, 12:37 PM
Smart quod bastardus
fredmeister's Avatar
Looks like a good fit.
Let us know how much it effects the oil temps so we have an idea how many degrees temp drop you get with this set up.
Were you having trouble with temps at the track or just tooliing around town?
I only wonder if there is a low pressure zone here on this outlet side of the cooler under the front of the car to help that little A/C fan push air across the cooler as it is not a very efficient fan in comparison to getting that cooler out in the air flow as in a RSR type bumper mount.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-14-2008, 02:16 PM
F350Lawman's Avatar
Do yourself a favor, get a pair of these tow hooks, they are available from our sponsor and made by Rennline. With my very low, and track stiff car these have saved my already! They are built to be tow/hooks and mini skidplates all in one.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 04-14-2008, 05:21 PM
Infidel
JBL930's Avatar
Fred
I'm now running a 993tt engine in the 930, the second oil cooler was a necessity, i'm hoping it'll do the trick, it may not and i'll have to go to the Setrab front mounted style. I was trying to keep the car looking stock, same tail, same front valance etc but the tail pipes now look like this so i may be flogging a dead horse
Old 04-14-2008, 05:26 PM
9dreizig's Avatar
JBL, what size is that cooler ??
"Todd"
Old 04-14-2008, 10:46 PM
Infidel
JBL930's Avatar
Setrab series 9 15 row part no. 50-915-7612.
Not sure how it will perform but i'm assured it will be fine, the only part that has me a little worried is the 90-degree elbow from the stock cooler, it looks a bit small? I'm probably worrying over nothing though.
Old 04-15-2008, 04:10 AM
A fellow Pelacanite
NathanUK's Avatar
Jonathan, if it is not adequate you could check that the smaller stock cooler gets the hot oil first and then the new cooler afterwards. This should help to dump a little more heat if it was done the other way round.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 04-27-2008, 01:37 PM
