resident samsquamch
sand_man's Avatar
Originally Posted by Jeff Alton View Post
Got the clean bill of health last week! Yipee, thanks for asking Rob.
Small update for today. We finished up the programming on the spinning machine so that we will now have a proper shaped and profiled outer wheel shell. It will have the soft edge that the fuchs has as well as a "ramp" instead of a radius where the tire well starts. Hard to explain in words, but suffice to say the outer shell will look "fuchs" and not "3 piece wheel"
Cheers
Glad to hear about your bill of health!
As for your description of the "new" Fuchs, I think I get what you're saying. For those of us interested in the 9s and 11s (17"), will this "ramp" still allow for deep dish?
-jeff
Old 09-17-2008, 05:52 AM
Jeff Alton's Avatar
Yes, this has no effect on where the center of the wheels sits vs the outer lip of the wheel.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7 Race Car, Cayman S 3.8, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap, Giant Roam Hardtail- to ride with the wife.
Old 09-17-2008, 07:15 AM
jbailey930's Avatar
Send a message via AIM to jbailey930 Send a message via Yahoo to jbailey930
Hey Jeff,
I am little late to this topic, but am interested once I wear out my SO3's. Can you post/email/PM your pricing? I'm running 7&9 Fuchs and love the monochrome and original look.
thanks
John
79 930
Old 09-17-2008, 11:11 AM
Jeff Alton's Avatar
John, click on my name and an "email" option will come up. Shoot me an email from there and I can get back to you with more info....
Cheers
Old 09-17-2008, 02:53 PM
There are 9's and 11's in the first production run.
Currently the build data looks like this....
7.5 and 8.0 for SC/Carrera front
9.0 for SC/Carrera rear
9.0 for Early turbo front
9.0 for Late turbo front
9.0 for turbo body with SC/Carrera chassis front
11.0 for turbo rear
11.0 for turbo body with SC/Carrera chassis rear
11.5 for turbo rear
cheers
What is different about the early and late turbo fronts? I have a 1976 930.
Are early and late turbos the same in the rear?
Old 09-17-2008, 03:45 PM
Jeff Alton's Avatar
Late turbo has the spacer incorporated into the front hub and requries 21mm more offset.
I would need to check on the 76/77 cars. I know the 78-89 cars are all the same on the rear.
Cheers
Old 09-17-2008, 03:59 PM
Jeff,
The choice to go 11.0 or 11.5 on the rear of a turbo (in my case, a '79) - is that purely up to one needing to roll the fender? Or can one get away with an 11.5 and appropriate rubber (315's?) without fender rolling? Would you recommend max 315's for 11.0 and 345's for 11.5, or something else?
Cheers,
Rob
Old 09-17-2008, 09:37 PM
Jeff Alton's Avatar
11 or 11.5 really does not matter much with a 315. Every one of these cars are different and each car can be different from side to side too. We have seen 1/4 inch differences in clearance from left to right on the same factory never hit car.....
One of the fastest track guys I know runs 275/245 while most prefer a 315 rear with a 255 front. I don't own a turbo bodied car anymore so I have not done any testing with different tire sizes to see the difference though...
Cheers
Old 09-18-2008, 07:57 AM
resident samsquamch
sand_man's Avatar
I know there is a certain "WOW" factor with the wide tires, but for my daily driver sled, do I need to run 315s on an 11" wheel? Or would a smalller width tire - 285 for example - require too much stretch?
-jeff
Old 09-18-2008, 08:42 AM
A fellow Pelacanite
NathanUK's Avatar
Sand, I have 285 on a 10" x 18" rim and it looks nice and tight, I think an 11" wheel would be too much of a stretch but as we know different models of tyre have slightly different widths despite the number.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-18-2008, 01:54 PM
I will add that 275/245 is honestly as much as you need on the street unless you are packing big horsepower.
Anything larger is cool but not really needed in many cases...
Old 09-18-2008, 02:13 PM
Crotchety Old Bastard
RarlyL8's Avatar
"Need" is not a word to be used in the same sentence as "930".
Smaller tires/wheels reduce unsprung weight increasing the nimble handling and quicker track times. They are cheaper too.
For the other 90% of the turbos that are not often tracked wearing 9.5 & 12s with 275/345 is just plain badass.
Old 09-18-2008, 04:07 PM
user & abuser
i believe i have 235/275 on 9 & 11's.... but the stretched look isn't the best IMO... in fact i like the slightly bulged sidewall...
vini vidi vici
Old 09-18-2008, 05:38 PM
resident samsquamch
sand_man's Avatar
Well I guess what I was getting at is that I prefer to run the smallest width tire possible, that will safely fit an 11" rim without an overly stretched look. I mean if I have to run 315s so be it...
-jeff
Old 09-19-2008, 03:57 AM
RarlyL8's Avatar
The smallest tire width on an 11" rim with no pucker, in theory, would be 305mm (if taking for granted that an 11" rim is actually 12" wide).
In reality you have to check tire manufacturers to get the actual section width. For example, a 295 BFG is wider than a 315 Pirelli. The 315 Pirelli will fit flush on a 10.5" rim!!
Old 09-19-2008, 05:04 AM
resident samsquamch
sand_man's Avatar
Many thanks, Brian!!! I know you have a wealth of knowledge in this area!!!
-jeff
Old 09-19-2008, 05:44 AM
SANDman
If you get 11"s, maybe you can try some really low profile (read competition) tires to get a smaller and lighter tire on a bigger rim??? They ought to have the most width out of any tires per size. Just a theory.
Old 09-19-2008, 08:24 AM
A fellow Pelacanite
NathanUK's Avatar
Remember that a smaller rolling radius tyre will also give you a smaller contact patch. 935 Norbert Singer.
Old 09-19-2008, 12:41 PM
It will also lower your gear ratio slightly the smaller the rolling radius and make it more like a 16" tire for 'gearing' effect. Or sort of in between a 16" and a 17" anyway.
Old 09-19-2008, 03:50 PM
resident samsquamch
sand_man's Avatar
Even though my degree is in accounting, boy I wish I would have paid attention to those Catholic Nuns trying to teach me math and science, back in the day!!! I feel like a dumb blonde (even though I have black graying hair) when it comes to gear ratios and such!!!
-jeff
Old 09-19-2008, 03:56 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
