Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Certified User
billjam's Avatar
Slow starter
My 85 Euro 930 usually blasts into life on the very first turn-over, however lately it has started to take about two seconds of cranking before it finally gets going. This problem is intermittent - some days it starts just like normal and other days not. When it does its slow-start thing, it usually gives a puff of smoke when it starts.
I haven't been able to identify any loose wires or hoses or anything else amiss and it always starts up OK when hot.
Got any ideas?
Old 04-19-2008, 05:36 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
If it's electrical, besides loose wires, check for corrroded wires. Might need to remove, clean them and reinstall (battery and starter). Otherwise maybe it's an accumulator issue. It's loosing pressure and has to build back up?
Old 04-19-2008, 11:59 AM
Certified User
billjam's Avatar
I haven't been able to find anything amiss with the electrics. All connections seem good everywhere including battery - besides if battery connection was suspect, it wouldn't crank as fast as it does.
Enlighten me - what is, or where is the accumulator?
Old 04-20-2008, 05:01 AM
It's the device next to and behind the fuel filter, above the longitudinal on the drivers side in the engine compartment.
It has a spring loaded diaphram inside that holds fuel pressure for a day or so after you shut the car off.
It helps during cold starts and smooths out the main system fuel pressure while running.
Old 04-20-2008, 08:20 AM
Certified User
billjam's Avatar
Thanks J.
I thought that item was a second fuel filter. I'll check it out in a few days - work has intervened for now.
Old 04-20-2008, 08:59 PM
