Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
79NINE30
930 1 Bar Boost Spring Yes Or No ?
My stock 79/930 runs great and I do not want to modify it much. I have been thinking about installing the 1 bar boost spring but I can not seem to find out anywhere what the performance benefits are and what the downside (if any ) might be. I switched my GHL pipes back to stock because they were so loud but I do notice a loss of power and am hoping this might get some of it back. The only other Mod is a K&n Filter. Thank You for your response.
79NINE30
Old 04-26-2008, 05:19 PM
IMO-------- NO.
Added stress on the engine that will shorten its life.
Old 04-26-2008, 05:26 PM
iamchappy's Avatar
Why not just add a MBC. Thats what i use, then you can set the wastegate at anything you want and use the spring you already have.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 04-26-2008, 06:09 PM
79NINE30
What is a MBC ?
79NINE30
Old 04-26-2008, 06:42 PM
wcc wcc is offline
wcc's Avatar
MBC - Manual Boost Controller
What are your uses for the car?
Track - No way for sure IMO.
Street - Possible if you have a larger intercooler and stay on top of your AFRs. The short bursts should be fine. This is what I currently have and haven't had an issue. USUALLY, the factory is conservative and they set the overboost cut off switch above 1.0bar anyways. I think it's at 1.2.
I have GHL headers, 1.0 bar spring, home made zork, and B&B intercooler and it is very nice. My car is street driven only. If I did track time I'd go back to the .8 spring.
Sorry for the 'long' answer but for your setup I would say NO!
Bill
Old 04-26-2008, 07:22 PM
David's Avatar
For a street car with a larger intercooler like Koklen, I think 1 bar is safe. If you don't increase fuel flow and get the AFR correct, it would probably hole a piston at the track, though.
2014 Cayman S
2011 Cayenne Turbo
Old 04-27-2008, 04:24 AM
e p slick's Avatar
No
No
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 04-27-2008, 06:34 AM
beepbeep's Avatar
No. Use boost controller (T-orifice, Dawe's device, EBC, whatever) and up it to 0.8-0.9 tops.
Thank you for your time,
Old 04-27-2008, 11:47 AM
Metal Guru
911nut's Avatar
Goran, what's the difference between using a spring vs. a boost controller?
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 04-28-2008, 01:54 PM
beepbeep's Avatar
Boost controller is adaptive and can be adjusted upwards or downwards depending on state of engine or ambient temp. Spring is permanent and requires dissassembly of wastegate bell. Removal of wastegate can sometimes be a frustrating process as things age.
Also, boost controller can only raise boost above the spring-tension controlled boost (often called "base boost").
So keeping a 0.7 bar spring and raising boost additional 0.3 bar with some variant of boost controller is much easier process than disassembling wastegate and fitting 1 bar spring.
There is an issue of harder wastegate spring preventing "wastegate creep". This is debatable issue and my personal opinion is that fitting harder spring to fight wastegate creep is collosal solution to somewhat nonexistant problem. Eventual boost creep can also be fought with EBC that doesn't introduce boost to wastegate bell untill boost reaches preselected value.
Old 04-28-2008, 02:23 PM
Metal Guru
911nut's Avatar
+1 on that. Last week I broke the flange off my J-pipe while trying to remove the OE wastegate.
Paul B.
'91 964 Turbo
Old 04-28-2008, 02:26 PM
79NINE30
To "MBC" or not to "MBC"
If you ad an MBC does your on board boost gauge still function properly ? Are the MBC's reliable? Easy to install and do you adjust them based on trial and error with the turn of a screw? Thanks
79NINE30
Old 04-28-2008, 04:34 PM
A fellow Pelacanite
NathanUK's Avatar
Will not stop the gauge in the car from working. They are simple and therefore reliable. There are a few variants.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-03-2008, 07:13 AM
hipdoc's Avatar
what's the best MBC for track use for custom ECU injected 3.3L 930? hipdoc
Old 05-05-2008, 08:51 PM
Large Member
krasuskyp's Avatar
Mine came with a GReedy Profec B Spec II installed, I've got it set to 0.8 max anything else I could hear slight detonation. My recent dyno run confirmed it's optimally set. I'm pretty happy with it, it's got a ton of features and adjustability / programability. I think they're somewhere in the ~ $400 range online.
OE boost gauge still works as well as it "works" (around 0.1 - 0.2 mine just 'sits'), but the EBC also has a built in gauge which can read in psi or bar.
HTH, good luck.
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 05-06-2008, 05:00 AM
A fellow Pelacanite
NathanUK's Avatar
These MBC's are very simple.
http://www.3barracing.com/products.htm
Old 05-07-2008, 10:46 AM
Here's another inexpensive brass one...
http://www.boostvalve.com/product.html
Never tried one but I think I'd like to... carefully!
Old 05-07-2008, 11:10 AM
