'84 dies on hard acceleration, restarts
Hi.
Started having an unusal problem. My '84 Carrera dies on hard acceleration (instantantly, as if you turned off the car). If I push in the cluth for a a few seconds the red engine status lights will come on, and I can pop the clutch and it will restart fine.
A few times, I had to push in the clutch again (twice) in order to get it to restart. But it has never failed to restart. (Knock on wood.)
Items which may help troubleshoot:
1. Car has 170K miles, original engine, never rebuilt.
2. Has never died in 1st gear. The higher gears seem more prone.
3. Seems to die more on the freeway (in higher gears).
4. Seems to die going *up* hills more (more acceleration going up a hill).
5. Car starts fine, especially cold. Warm/hot starts are not so instantaneous.
This problem is unsettling, as you might imagine.
Any ideas what might be causing it?
Is there a chance it might be the DME relay?
Old 04-28-2008, 07:55 AM
clogged gas tank? Pinched fuel line allowing only partial fuel delivery? When was the fuel filter last changed?
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
1973 911S Glacier Blue
Old 04-30-2008, 10:25 PM
check your overboost switch
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-01-2008, 04:17 AM
the fuel filter has not been changed in some time. Tho I didn't think that would kill it so suddenly. I thought, if the fuel filter were clogged, it would simply run rough during acceleration. You think it could be the fuel filter?
How do I check the overboost switch? What does that do?
Old 05-01-2008, 07:06 AM
dean- the car is a 84 carrera. he posted on the wrong forum
if it were turbo powered, then your suggestion would apply
1970 911 Spyder
1970 911S Conda
Old 05-01-2008, 07:36 AM
Not sure how I posted in the wrong forum. Sorry. I will repost in correct one.
Old 05-01-2008, 04:33 PM
woops, It would also help if I could read
Dean
Old 05-01-2008, 07:01 PM
