sudo apt-get purge 930
Throttle body o-ring
Does anyone know the part number for the lower throttle body o-ring? Pelican sells only the upper. If someone has a link to one that would be great.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
you mean 999 701 124 40 isn't what you're looking for?
I don't know if that's it. The description doesn't say it's for the turbo models. If it is, thanks. Can you or someone verify that it the correct one for a 1979 turbo? The upper ring, 999-701-477-40-M213 specifically states turbo but the other doesn't.
is it here?
they squish photos pretty good don't they? they use to turn out better
i think thats it man 468-40 Last edited by jbrinkley; 04-27-2008 at 08:35 PM.. |
999 701 468 40 is the correct part for the 3.3 according to my Parts and Techninal Reference Catalogue......
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
That's the part I need. Thanks Guys.
No wonder I couldn't find it. It is used in several applications:
Cam End Plate O-ring, 911/911 Turbo (1965-89), 924S, 944, 944S, 944S2, Throttle Body to Manifold Seal, 911/ 911 Turbo (1973 1/2-89) But it doesn't show up with the upper ring in the parts section.
