Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Gotta Jibboo
BSiple's Avatar
Send a message via AIM to BSiple
Porsche Crest Momentary loss of power???
The car has been acting a bit strange lately. Sometimes, when on a very bumpy road, I get a momentary cut out of power, the car feels like it hesitates for a second. Once it does that, sometimes the power comes right back, and sometimes it does it a couple of times if the road surface is really bumpy.
I plan on checking all the electrical connections this weekend, was just wondering if anyone knew of any grounds that could be causing this. I thought maybe the overboost sensor (since that's what it feels like) wire might be a bit loose, and I have a little jumper that the previous owner used to ground the wire to the intercooler with (bypassing the overboost switch), so I connected it and then reconnected the switch, so the wire is a little longer to rule out that.
Any thoughts or reccomendations?
Bill
2003 996TT
1992 964 Turbo (sold) Holy crap are these expensive now!
1986 911 Cabriolet (sold)
I don't know why I do the hillbilly things I do.
Old 05-02-2008, 12:38 PM
rsrmike's Avatar
you may try connecting a test light via jumper wires to various places, fuel pump in engine compartment, fuel pump relay, etc. maybe you could tell if it's loosing fuel that way. It could be the fuel pump relay, or whatever is triggering the relay... It's most likey fuel as you didn't mention the tach acting up... Although that lead me to a brain fart on your situation so here goes... When whoever installed your electromotive for the PO, did they leave the stock ignition sensor and control unit in place and just remove the coil and such? that would probably have been a smart thing to do. I wish I'd thought of that years ago the only time I twinplugged a c2t. oh well, just a thought good luck!
Old 05-02-2008, 03:03 PM
A fellow Pelacanite
NathanUK's Avatar
Check your battery connections too.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-03-2008, 02:40 PM
Gotta Jibboo
BSiple's Avatar
Thanks guys. I will need to take a picture for you Mike, as I think a lot of the stock ignition stuff is in there. I did find a connection that was loose, but will spend some more time tomorrow and will take some pictures.
Bill
2003 996TT
Old 05-03-2008, 06:40 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
