Porsche Junky
mede8er's Avatar
Ladedruck....
How do these things work??? Where do the lines go???
TIA....
1986 930 RUF equipped
Old 05-03-2008, 03:38 PM
Porsche Junky
mede8er's Avatar
BTW...ladedruck is load pressure...It's what RUF calls their adjustable boost control.....
Old 05-03-2008, 05:42 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I'm glad you explained what it meant, but I still don't know. Sorry.
Old 05-03-2008, 06:53 PM
Porsche Junky
mede8er's Avatar
Well...I know it interfaces somewhere in the turbo boost configuration...don't exactly know where or what it does...but the performance sure is enhanced....
Old 05-04-2008, 08:08 AM
Acceleration Junkie
What it does is borrow positive pressure from the intake plenum and apply some of that positive pressure to the normally-vented-to-atmosphere port and its isolation diaphragm in the wastegate. The diaphragm acts on the wastegate's boost spring to prevent it from opening at its nominal/normal pressure. The higher the pressure on the normally vented diaphragm is, the higher the boost pressure needed open the wastegate.
Bottom line - more diaphragm pressure, more boost, more compression, more fuel, bigger bang when something lets go.
Old 05-04-2008, 09:22 AM
Porsche Junky
mede8er's Avatar
AHA....yes...get a little over 1 when fully engaged....get .9 when disengaged...just another fun component, hehhehheh....
Old 05-04-2008, 11:17 AM
A fellow Pelacanite
NathanUK's Avatar
You have to place a tee in the line before the WG. You then run from the new tee to (the inlet of) your gadget. The other line from the gadget (the outlet) goes to the top port on your wastegate (what was the vent).
Thinking about it, I see no reason why you couldn't tee off of the brake booster line or the line to the aftermarket clock replacement gauge (if you have one) if you wanted to.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 05-04-2008, 12:44 PM
A fellow Pelacanite
NathanUK's Avatar
Oh, it works by letting an - adjustable by you - amount of pressure back on the vent of your wastegate and therefore increase your boost pressure before allowing the wastegate to open.
Old 05-04-2008, 01:07 PM
