Will these wheels fit a 930?
Would the following wheel and offset fit on the 930? Thanks
18x9 ET18 18x8 ET31 |
Yup, those offsets should fit just fine on a pre-ABS car (Ruf used 30.4 and 17.7 for the same fitment on 17" wheels).
Only thing is that 9's & 10's would be better for a 930 - I have 8's & 9's on my SC-bodied car.
'77 S with '78 930 power and a few other things. |
I have 18x9's on my front and find the steering is just a bit too heavy.
I think 8's are good up front, and for the rear, go as wide as you can without rubbing, 11" - 12". |
I have 9x17 and 10x17. For me, steering is OK, maybe a bit heavier when parking. I also think (just my thoughts, no experience) that too wide in the back together with narrow front will end up in grip loss first in the front, what I really dislike.
Roland 930 Turbo '81 Too many modifications to list |
Thanks for the feedback. Would this size be a better fit on the 911SC or non-turbo?
It's not even close to being OK without custom sizes, offsets and/or bodywork (extended flares).8's & 9's bolt straight into flared (but non-widebody) cars and allow the use of quality tires in the cheap, easy-to-find & popular sizes like 225/45 (does require the front fender to be rolled) & 255/40. (You can probably squeeze in slightly wider tires - especially at the rear, but these are taller/heavier/harder to find/not available in all brands/more expensive. And may also require spring plate bolt heads to be shaved, oil lines relocated, fenders rolled and possibly more aggressive alignment. Diminishing returns... IIRC, 225/255 is wider than Ruf used on the Yellowbird CTR anyway, with 8J/10J and ~470HP - think they spec'd 205/245 back in the day).
