Ptoscano's Avatar
Send a message via Yahoo to Ptoscano
boost gauge
Does anyone have experience with installing a brake booster mounted boost gauge ? I have installed and have no boost reading. Line to gauge has vacuum and is before check valve so it will read positive pressure of manifold but its not. Gauge checks out to be working properly. Any ideas ?
2012 XC90- wifey
2011 BMW 535I -Daily Driver
911/964 Widebody Cabriolet-Protosport Stage 1.5 Turbo
Old 05-15-2008, 05:32 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Sounds like you may have a leak else where in the line. Possibly at the rear or the car.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 05-15-2008, 06:22 PM
Smart quod bastardus
fredmeister's Avatar
If it reads vacuum but no boost then you cannot have a leak. It would not do one without the other.
Make sure the check valve is installed correctly as it only works one way. Most likely the cause.
Could be the gage is broken as shipped. I had one sent to me that was broken right outta the box. Had to send it back for a new one.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-16-2008, 06:19 AM
