Rough idle after oil change, need help just took delivery of my 76 turbo
I just took delivery of a 76 turbo 47k miles, had a full top end rebuil in 2000 with 40K miles, car needed an oil change, so i read nearly half of the 40+ page thread and decided i didnt want a synthetic oil since it has only run conventional. Anyways, i found a border line oil at autozone with an sl rating that should have enough zn and phos. i put in a 20w50 weight with a new filter. Now the car runs extremely rough at idle until temp comes up and it smoothens up. I looked at the manual and it says that it takes 10.6 quarts and prefers to run sae 30. I am going to change it tomorrow again but need recs from what i can pick up locally or shoudl i just bite the bullet and wait for some swepco. thanks.
Old 05-25-2008, 07:38 PM
Large Member
krasuskyp's Avatar
Congrats on the '76 - we want pics! Sounds great.
Sorry I'm of no help otherwise - I just bought 12q Shell Rotella 5w40 to do my first oil change yet on mine. Any suggestions where to get filters and which to get? I'll do a search I guess...
Good luck - let's see it!
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 05-27-2008, 05:49 AM
Crotchety Old Bastard
RarlyL8's Avatar
Oil is oil (within reason). A different brand or weight shouldn't make your engine run rough when cold.
Something likely unrelated has changed during that time. There are a few things that will cause a rough cold idle, generally fuel related.
How long have you had this car? What are the climatic conditions?
Old 05-27-2008, 06:33 AM
You might have over filled it and gummed a plug. I over filled once and had oil dripping from every where. Maybe you sucked a lot down into the engine through the blow by and vent tubes. Pull a couple of the easier plugs and check them for fouling.
911rudy
Old 06-03-2008, 10:37 PM
