Doug Siegel
Well put Brian.
88' blk/blk 930: Haltech EFI, Twin Plug, Pauter Rods, Nascar Bearings, custom crank work, dowel pinned case, ported manifold and heads, Kokeln I/C, SC Cams, Turbonetics ball bearing 62-1, BB headers, RARLYL8 Zork, additional 993 oil filter, plx/inyourface gage, RS style coilover, Fikse FM10-17 wheels, TIAL 46mm 1 bar. (where the heck did all my money go?)
Old 06-01-2008, 03:46 PM
Today I checked system pressure and I was at 95psi.
When I removed the system presure regulator from the IA modified CIS head there were only 2 shims under the spring, a thick one and a thin one.
The factory manuel say's there are 3 shims in a stock fuel head.
When I put it back in with out the 2 shims I had 75psi. I figured thats got to be too low so I put the thin shim back in and am now at 80psi.
Road tested it and my LC-1 AFR gauge decided not to work again.. even after another free air calibration it still won't work so I don't know what my AFR is now.
It runs ok so I'll leave it the way it is until I get the LC-1 working again if thats possible.
I can still smell ultra rich exhaust when I accelerate hard and with no sound pad and the windows up I hear only an occasional single "tink" sound up around 6500rpm which is detonation. At least it is not a steady crackleing of detonation sound.
I can only hear detonation or pinging with the windows up, and removing the rotted out old sound pad helps to hear it.
I'm going off topic now but I should mention that my engine is set up with Powerhaus group B cams which are longer duration and timed later than 964 cams, B&B headers and single out muffler, K27HFS turbo, Garretson long neck intercooler, IA modified fuel head, Brian Leask adjustable control pressure regulator, and running 1-1.1bar with an adjustable boost valve, and .9 bar spring in the wastegate.
It's fast... estimated around 420HP at the flywheel.
The group B cams are in there from the previous owner. The powerband is very strong from 4000-7000rpm.
I will put in a set of SC330 cams I have for more midrange torque probably next winter. That should make it better for street driving.
edit: my engine also has raceware rod bolts.
Old 06-01-2008, 04:58 PM
A fellow Pelacanite
NathanUK's Avatar
Brian, how do head studs affect fuelling?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-02-2008, 12:16 PM
Me like track days
Craig 930 RS's Avatar
Looks like he's 'stuck' with the IA head he's got, so he just might *have* to work in reverse.
If safe, (and suported by a decent IC) - a tad higher boost. etc.
Not too many other options, unfortunately.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-02-2008, 12:44 PM
Crotchety Old Bastard
RarlyL8's Avatar
Brian, how do head studs effect fuelling?
It's not so obvious. ARP, or like, head studs allow you to extend the RPM range of the engine. More RPM = more fuel needed. I found that my 11.8 AFR @ 6000rpm was leaning to 12.2 by 7000rpm.
Old 06-02-2008, 12:57 PM
A fellow Pelacanite
NathanUK's Avatar
Ah, OK. You got me there!
So long as you do the rod bolts too though.
Old 06-02-2008, 01:11 PM
Porschephd's Avatar
Well not really, he can send it back and I can recalibrate it to a lower level, but still higher than stock.
Stephen
94 3.6Turbo 6-speed AWD
Old 06-02-2008, 01:46 PM
one of the great unwashed
patkeefe's Avatar
Stephen:
I'll send you an email; I need my head recalibrated also.
TIA
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 06-02-2008, 02:19 PM
me too...
jim
Old 06-02-2008, 04:35 PM
Porschephd's Avatar
Love it, I never thought I would see the day when CIS gave TOO much fuel
Stephen
Old 06-02-2008, 08:06 PM
lol!
Old 06-02-2008, 08:19 PM
resident samsquamch
sand_man's Avatar
Originally Posted by porschephd View Post
love It, I Never Thought I Would See The Day When Cis Gave Too Much Fuel :d
What's the world coming to?
Old 06-03-2008, 02:53 AM
