Ac From Only Drivers Vent-all Others Just Hot Air
I have a ’96 911, which was stored in a climate controlled space for winter.
When I took it out to drive in the early spring and turned on the AC, cold air only came out of the drivers side vent… hot air flows from all other vents (center, defrost, floor-feet and pass-side vent).
The slide switches seem to have little affect, and the dial for temperature control has no affect in changing the level of heat or cool when AC is off (or when its on for that matter).
So, I turn on the AC to regular or to “max’ and out comes the cold AC from that one drivers side vent (by the door), but hot air jams out of any other vent.
Any ideas of what’s going on?
Thanks-
Bruce
Old 06-05-2008, 10:12 PM
A fellow Pelacanite
NathanUK's Avatar
Wrong forum, this is the original 911 & 930 forum.
I think you need the 993 forum.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-06-2008, 02:12 PM
