Show me your transmission cooler setup
OK, rather than me try to figure it out from scratch - what have you done to install a cooler in your 930 on your 930 box?
I've got the Tilton pump - thanks PurpleHaze - and now I've just got to figure out the best place to mount the pump, the cooler, route the lines, etc.
So if you've done it, I'd like to see it:
1. Where did you mount the pump?
2. Cooler mount point?
3. What size lines?
4. Did you pull fluid out of the drain plug area of the tranny? and where did you pump it back in?
5. Did you use an external tank to hold more fluid to compensate for the fluid required to fill up the lines/cooler/etc.
Any other info you've got, I'd like to hear...
(BTW I did a search, but didn't really find what I wanted to see)
Thanks,
Brian
Brian Keith Smith
Competition Custom Paint
1983 930
My Track Videos
TEC3 EFI Conversion on 1983 930
Old 06-07-2008, 06:58 PM
iamchappy's Avatar
Not a 930 box but this is how i plumbed mine using the drain and fill plugs drilled out and tapped.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-08-2008, 03:04 PM
Thanks man. I'll PM you later. Got some questions...
Brian Keith Smith
1983 930
My Track Videos
Old 06-08-2008, 03:07 PM
IamChappy:
Any more pics of the plumbing in/out of the tranny?
Brian
Brian Keith Smith
1983 930
My Track Videos
Old 06-09-2008, 10:39 AM
iamchappy's Avatar
I do somewhere. I'll look for you..
87 924S
Lexus SC400
Lexus LS400
Old 06-09-2008, 06:07 PM
iamchappy's Avatar
The first shows the top fill plug fitting were it runs back in. The fitting coming out the side of all the fittings crap is the trans temp sender which is going to be moved down to the bottom drain plug fitting between the tranny and the cooler or i am going to tap it into the
case.
The second shows the areas i tapped the plugs, the hoses are there to keep all from spilling out.
87 924S
Lexus SC400
Lexus LS400
Old 06-09-2008, 06:40 PM
juicersr's Avatar
Chap, what kind of cooler are u using? How is tranny fluid being circulated through the cooler?
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 06-09-2008, 10:37 PM
Wer bremst verliert
JohnJL's Avatar
Did you observe higher than acceptible transmission temps? I was about to order the same pump and bits from Summit and spoke to my local shop looking for the 2 20 (22?) mm adapter fittings needed to plumb the lines into the fill and drain ports. They (Nathan) stated he had rarely seen issues with G50 transmission temps on anything short of endurance races. I was surprised at this as EC track temps regularly hit 45 deg celcius and it can be damn hot out there. However he talked me out of adding the complexity and weight without seeing truely high temps. I was very wary of not adding the cooler (to the $12,000 transmission!) but he convinced me to observe the data first.
Have you been seeing high temps and if so under what circumstances?
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-10-2008, 02:45 AM
iamchappy's Avatar
Well as you see mine is a 901 trying to hold back that engine, spray bars over the gear sets and bearings on these transmissions are the way to go. in your guys cases, using 930 or g50 transmissions, unless your racing i doubt you really would need one. I think my cooler is a fluidyne, the pump is a Tilton.
I plumbed mine in because i had the stuff laying around to do it, and have too much time on my hands. I am hoping that the cooler will buy my 901 a little time, but adding the spray bars is something i need to do to finish it off right like in this picture from Patrickmotorsports.
87 924S
Lexus SC400
Lexus LS400
Old 06-10-2008, 04:51 AM
Wer bremst verliert
JohnJL's Avatar
Patrick did mine. Shortened G50, Guard 80 LSD. 450 RWHP is the goal...have you measured temps? PR Tech says they have to work really hard on Eastern Creek to see more than 200F...
Old 06-10-2008, 05:43 AM
MikeD930's Avatar
Question
iamchappy,
For the trans cooler, did you use an oil pump? If not then is the trans oil presserized to the trans cooler? Not sure how this system works without an oil pump. Thanks for any info.
MikeD
'87 930
Old 06-10-2008, 07:40 AM
iamchappy's Avatar
Electric oil pump -
http://www.pegasusautoracing.com/productdetails.asp?RecId=156
87 924S
Lexus SC400
Lexus LS400
Old 06-10-2008, 08:30 AM
