Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Dyno question
Does it matter if the run is run in 3rd or 4th gear on our cars?
And... I recall reading somewhere that there's discrepancy between Dynojet type vs. Mustang ones? What's the difference?
thanks!
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 06-10-2008, 01:26 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
sub'ing AND not to hijack the thread, but as long as you're commenting.. What's a typical dyno session cost ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-10-2008, 01:37 PM
Smart quod bastardus
fredmeister's Avatar
It should not matter what gear you run, the higher gear the better because your run time is longer before maxing out rpm. You need to accurately give the gear ratio including the final drive so that the calculations will run properly thats all. Most places like to run in the gear that yields a 1 to 1 final drive ration so 3rd gear is probably the choice on a stock 930 box.
Accuracy of each type of dyno is all the difference and I am no expert but I know from reading other posts that one type typically overestimates h.p.....cannot remember which....and alot of guys like to hear more h.p. than reality to make the ego feel better.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-10-2008, 02:55 PM
what? me worry?
TimT's Avatar
Power pulls are made in the gear closest to 1:1 ratio.
Tuning pulls are made running through all the gears, and applying loads at various points on the rpm band in each gear, and setting a/f appropriately. Then fine tuning timing
I think we charge $75 for a single setup and power pull, and $150/hour for tuning. Bill handles all that so I'd have to check for the exact #s
Yes different dynos type and mfgs show slightly different power outputs. One reason why SAE corrections are used.... to try and get a level field between all the various mfgs.
Even running the same car on the same dyno can lead to different numbers, i.e. when heat soak starts to rob power, if tire pressures arent correct you might get slip on the rollers, lots and lots of variables.
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 06-10-2008, 05:11 PM
Wo ist die Rennstrecke?
DonE's Avatar
I have a 4sp stock tranny, and run each dyno in 3rd.
There is a reason they call them Dynojunk. However, if you use a dynojet as a baseline, continue to use that same unit as you make adjustments.
A couple of years ago, I went to local dynojet dyno to test the infamous powerflow intake to see what kind of gains I had (if any). I did a couple of pulls, but his AFR was not working, so I went to another shop across town that had the same model. Although their AFR was working, the pulls were more than 40rwhp lower. I asked how this could be and he said the correction factor used at the first place could have been different. In fact, he asked what HP I would like to see and he would set the CF so I could "show off".
Old 06-10-2008, 05:21 PM
David's Avatar
Made my runs in 3rd also. Making runs in 4th will be almost 190mph, which seems a little unsafe to me.
2014 Cayman S
2011 Cayenne Turbo
Old 06-11-2008, 05:46 AM
Large Member
krasuskyp's Avatar
I ran mine last month to establish a baseline - they ran it in 3rd, and it was $85 for 3 pulls. Mustang dyno, and from what I understand they read slightly lower than a Dynojet.
Whatever, I couldn't care less about the net numbers, just the curves and the deltas to come when I get to mods down the road.
An interesting experience tho certainly, was fun.
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 06-11-2008, 06:21 AM
Does this mean that if a taller ratio (like 4th gear which is more like 0.7:1) will result in different (lower?) numbers?
thanks!
Old 06-12-2008, 05:24 PM
A fellow Pelacanite
NathanUK's Avatar
Yes, but the software corrects the number.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-13-2008, 11:51 PM
Well, maybe this explains the VERY low number I got - 298hp/296ft-lb @ 0.8 bar
The only question I was asked is how much does the car weigh.
The same dyno said I had 250hp @ 1 bar when the car was CIS with stock engine internal (but same K27HF and headers) which I thought is very low as even a stock 930 should have that...
Old 06-14-2008, 04:52 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
