gumba's Avatar
front spoiler oil cooler options
I have an old early '80's front cooler mounted in the spoiler, approx. 6"x13". The engine temps are 200-210 range. While this is fine for street driving, I know it won't work for the occasional track days. Are most coolers about the same in efficiency, or are some better than others?
I boxed the back of the cooler so it ducked out the bottom of the car instead of hitting the body behind the cooler, but didn't make any difference temp wise.
The car is a slantnose so I can't add a fender mounted cooler.
Old 06-12-2008, 02:25 PM
200 - 210 is not bad.
I ran the 28 brass cooler in the front passenger fender for years with an occasional 240* at the track; then mounted a Setrab behind the front valance connected in series with the fender one. Temps don't go over 200 anymore whatever I do at the track; however, no major improvement in traffic.
Old 06-15-2008, 10:08 AM
930gt-40r's Avatar
Im setting up to run twin 964 oil coolers in the front of my car, Ruf used this setup (I think)and I think it is a great idea.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 06-18-2008, 01:31 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Check out Fluidyne's website. I use an airbox650 and in FL (HOT) my car always stays around 178F. A good source to buy their coolers is from Hoerr Racing Products. Now I must mention that these coolers come with -12 AN in and out but I cut them off and replaced them with -16 fittings. The -12's will work fine but for my setup I needed the larger line.
Old 06-18-2008, 02:30 PM
iamchappy's Avatar
I've seen remote oil filter adapters that install where the engine oil cooler mounts on the engine for those who use external oil coolers, does anyone know where i can source one.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-18-2008, 03:28 PM
gumba's Avatar
I just had one installed on our 3.4 race motor at Jerry Woods. They carry the kit. They estimate this may increase your oil temp by 30-40 degree.
Old 06-18-2008, 03:32 PM
iamchappy's Avatar
I have a nice sized front cooler.
Great, Smart Racing Catalog shows them, Thanks!
87 924S
Lexus SC400
Lexus LS400
Old 06-18-2008, 03:36 PM
what`s the purpose of a mod that increases oil temp?
my life begins at 150MPH
Old 06-18-2008, 08:30 PM
iamchappy's Avatar
I see it as extra filtering, if anything did let go in your engine it would stop there.
I would think if you have a large enough external cooler that receives good air flow there shouldn't be
any significant temp increase.
87 924S
Lexus SC400
Lexus LS400
Old 06-19-2008, 05:20 AM
Forced Induction Junkie
WERK I's Avatar
The factory Special Wishes cars in the early to mid-80's had the front mounted oil coolers that were a bit over engineered for the street. Lots of flow.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-19-2008, 06:50 AM
resident samsquamch
sand_man's Avatar
That's nice, Dave!
-jeff
Old 06-19-2008, 07:08 AM
So who sells the nicest bolt-on front cooler kits? My opening is 23" x 6".
Old 06-19-2008, 09:02 AM
gumba's Avatar
This one from Setrab looks pretty nice.
http://www.patrickmotorsports.com/part/425/
While these coolers seem fine for the street, how are they on the track? Not sure one cooler is enough.
I run twin fender mounted carrera coolers on our 3.4 n.a. race car which work fine. The temp stays around 190-200, even in 100+ degree weather.
Old 06-19-2008, 10:15 AM
onboost's Avatar
I've got the same one as Dave (Werk-l) has pictured.... a very sturdy unit with no cooling issues.
Paul
RGruppe #180
Old 06-19-2008, 12:05 PM
935TURBO's Avatar
I had the same on my factory 930 SE and I had to make some modifications to fit my 935 bumpers...so I designed and made that......D.I.Y.......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 06-19-2008, 11:12 PM
935TURBO's Avatar
There are some more details here.... Front Oil Cooler 930 S / 935 Bumper
Old 06-19-2008, 11:16 PM
Is there a company out there offering a plug-N-play front oil cooler kit? I'd rather not mess around sourcing fittings and making brackets.
Old 06-22-2008, 07:02 PM
petri's Avatar
I had a strong heating problem in track days in my Green one (also street legal), even if no problem at all when at street.
Now there is no problem with the following installation;
2 x Setrab 265 x 265 +
1 x Setrab 700 x 200
Note, since the photo has taken, the oil lines has changed douple that wide (interior measure of the line always more than 18mm, the bigger the better) to make sure that oil pump doesn't cavitate and get broken.
The final system is very satisfying . No heating problems whatsoever hard I push .
In my 3,6 natural aspirated "RSR" I have similar front cooler than you have in slant nose pics, and that car runs all the time in the track just slightly below the red line. That particular car will get next winter 2 x 964-coolers to corners as an addition to act together with the center cooler to make sure I wouldn't blow the engine or kill the oil (Valvoline Racing VR-1 10-60) too fast.
Garage: Strosek 911 RUF BTR|Strosek 911 3.6 rat RSR|Strosek 928SR|928S4R|928S|996C2RSR...and more... Altogether 11 Germans - 3 Italians - 2 British
Old 06-22-2008, 09:31 PM
jbailey930's Avatar
Send a message via AIM to jbailey930 Send a message via Yahoo to jbailey930
Mine is B&B =
http://www.bbexhaust.com/car/porsche-oilcooler/
as seen on this site, sorry old web site
http://members.rennlist.com/jbailey/
didnt have to make tabs for the body, bolted through fender and ran aeorquip lines.
John
79 930
Old 06-24-2008, 10:43 AM
Wo ist die Rennstrecke?
DonE's Avatar
I also use fluidyne coolers - one in each front wheel well and no engine cooler. A couple of weeks ago, at a Road Atlanta DE, the ambient air temp was 96, track temp of 115 and my oil temps hit 230. Around town, it never moves from 185 (engine temps measured by the ECU).
However, they require some fabrication to fit.
Old 06-24-2008, 04:52 PM
