gumba's Avatar
rear fender mounted oil cooler
Does anyone have a diagram showing how the rear right fender oil cooler was plumbed in and what cooler was used.
Old 06-13-2008, 10:34 AM
onboost's Avatar
Think the cooler used was the same as the one use for the front.
When I did a slant nose conversion on the 77 930 I had we used a front cooler also. If I can find the diagram I will post. It had part #s and everything. Can't promise I'll locate though but will check.
Paul
RGruppe #180
Old 06-13-2008, 11:28 AM
one of the great unwashed
patkeefe's Avatar
I'm putting a cooler in the left rear fenderwell on the turbo SC, so the oil I pump from the catch can will go through it instead of directly back to the sump.
I'll try to get a photo this weekend.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 06-13-2008, 12:09 PM
gumba's Avatar
I have a front cooler in my slant. The temp is fine for street driving but I don't think it will be enough for the occasional track day. There's a track DP on my site that's running both coolers (one in front and one in the right rear fender) with substantially more h.p. than mine with no problems. Thought that might be a good way to go.
thanks,
Harold
Old 06-13-2008, 12:24 PM
I believe that you'll need some kind of air ducting also to make it work efficiently - air flow through it... That fender well is like a pocket with little, if any, air flow.
Old 06-13-2008, 08:21 PM
A fellow Pelacanite
NathanUK's Avatar
Not sure I'd want to add more weight in the rear. Can't you mount a cooler up front?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-14-2008, 02:59 AM
onboost's Avatar
If the car is a slant then should already have ducts in the rear.
RGruppe #180
Old 06-14-2008, 06:59 AM
gumba's Avatar
The car has the ducts in the rear. I already have a spoiler mounted cooler in the front. The weight increase would be around 10 lbs.
Old 06-14-2008, 08:50 AM
A fellow Pelacanite
NathanUK's Avatar
Did you include the oil in that figure
Old 06-14-2008, 09:06 AM
Blackbird Pilot
Reaper930's Avatar
What size coolers are being run in the quarters? I'm thinking about doing a dual cooler setup one in each rear fender scoop.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 06-23-2008, 07:14 AM
gumba's Avatar
I'm trying to confirm if this a 930S cooler. It's approx. 1" shorter & narrower than a Carrera cooler. I test fit it in the fender and it would be tight, but would work. If this doesn't work I would get one of the Setrab coolers.
Old 06-23-2008, 07:53 AM
onboost's Avatar
Gumba,
Sorry, I looked but could not find the old info I had. In the event that I locate it.. I will still post! Renovation going on at home, I can barely find my underwear!
Paul
RGruppe #180
Old 06-23-2008, 08:52 AM
patkeefe's Avatar
Pictures
I got sidetracked a bit...had to R&R the engine for the blown up airbox; just put it back in today. Finished the rear fender oil cooler also.
This is actually a NOS VW oil cooler, the aftermarket kind that went over the fan opening. I build a frame for it, welded in a mount bracket and plumbed it in AN-8. It comes out of the Tilton pump which I use to drain the turbo, and back into the left chain cover. It's sole purpose in life is to cool the oil from the turbo before dumping it back into the case.
I now have four oil coolers: engine, right front fender, center front and this one. I have to be close to the world record by now.
Patrick E. Keefe
78 SC
01 Boxster
Old 07-27-2008, 02:37 PM
gumba's Avatar
OnBoost, it is a 930s cooler. A rennlist member sent me a bunch of photos showing the installation on his 930s. There was also one at the local race shop so I got a good close up look.
Harold
Old 07-27-2008, 04:25 PM
Send a message via AIM to Chuck Jones
87 930 oil cooler w/factory mount
Here's a shot of my oil cooler mounted in the left rear fender...if you need more shots, let me know. The picture you show of a 930 oil cooler has the louvered stone guard in place, but it's the correct oil cooler. Just make sure you test it for pressure before going thru the trouble of mounting it then find out it leaks.. That louvered stone guard covers the radiator-like core. In my picture, I use a home made stone guard out of a piece of screen material and not the louvered OEM one...although I do have a new original stone guard that I'll put in someday. Chuck
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 07-28-2008, 03:11 PM
Blitzkrieg
jly535's Avatar
Looks like right rear fender to me!!!!! I consider passenger side the rightside from sitting in car. Looks nice though!!
Old 07-28-2008, 03:44 PM
Shucks....I got my directions mixed up....you're absolutely right...it is right....I guess I get confused by you Euro folks who drive on the wrong side of the road.
Old 07-28-2008, 04:02 PM
I also have an Oil Cooler in the right rear fender that has the grates, but I do not have a factory slant. Also unlike Chucks, mine is plumbed via the bottom, not the top, w/ no stone guard.
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 07-28-2008, 05:49 PM
patkeefe's Avatar
Chuck:
That's a nice setup! Is that the only auxilliary oil cooler on the car (guessing from the thermostat)?
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 07-28-2008, 06:19 PM
Plummed from the bottom? I haven't seen one plumbed from the bottom, but truthfully, I don't know if it makes a difference except for the more protected routing of the oil lines....do you also have the cut out fender wells to allow the air to go thru the radiator? There is also a small fan grate on the bottom that protects the blades and blows air directly up and over the cooling vanes from below. It's thermostatically controlled.
Old 07-28-2008, 06:22 PM
