Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
question for Brian ( Rarlyl8)
Brian, I've done a search and can't find the thread on your low cost air box replacement.. I'm thinking of doing it, it should be alot handier when working on my UNCIS that I'm about to order. What did you do with all the hoses that went into the box ?
What size /brand filter did you buy ??
Todd
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-15-2008, 05:49 PM
iamchappy's Avatar
Are you talking about one of the air cleaners like on top of my engine. there a standard size air filter for a four barrel carb you can get at any local auto parts store, the filters are cheap like 6 bucks you can make a lid or just buy one for about 20 bucks for both. they come in 2, 4 and 6 inch heights. They seal up perfect.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-15-2008, 06:34 PM
9dreizig's Avatar
Yup that's the one, didn't know the exact sizes.. So just plug all the oil vent lines etc going into the airbox ?
"Todd"
Old 06-15-2008, 08:13 PM
iamchappy's Avatar
Dont plug, I installed an oil catch can to vent the hoses that went to the air box.
87 924S
Lexus SC400
Lexus LS400
Old 06-16-2008, 05:05 AM
Crotchety Old Bastard
RarlyL8's Avatar
I put little filters like this one on all the hoses.
Old 06-16-2008, 05:18 AM
another small temporary air filter
This one was about $19 at advance auto parts in south florida.
I taped off the inside and outside elements real good and then had to cut the hole in the bottom bigger to fit on the CIS.
Luckily the only area on top to drill holes for the mounting screws without going through the filter element lined up just right.
Then I used a large rubber O-ring made for holding the fiberglass battery side covers on a mid 70's BMW motorcycycle rubber band style, fit just right under it to help make an air seal against the bottom of it and the slightly recessed CIS air filter flange.
I used small breather filters on the gas tank vent hose and oil tank breather hose and my car has headers and the aftermarket turbo sump tank doesn't have a vent hose so that ones gone.
This is just temporary until I get my cars AFR's somewhere near right if thats possible... because it doesn't flow or filter air anywhere near as well as the factory air cleaner/silencer housing.
Old 06-16-2008, 04:28 PM
RarlyL8's Avatar
My filter will flow at least 400Hp to the wheels. Might work better than you think.
Old 06-16-2008, 05:58 PM
I installed kind of manifold hose conecting all the breathers to the top of the air filter holder, works great.
Old 06-17-2008, 06:10 AM
Banned
Hello - I just sent you a PM regarding some information about this filter . . .
Ron
Old 06-24-2008, 12:31 PM
