Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Bump steer
What is a "bump steer kit" and who sells them for a 965 ?
Old 06-15-2008, 06:14 PM
bump Guess no one knows.
Old 06-16-2008, 11:29 AM
full quack's Avatar
Send a message via Yahoo to full quack
Bump steer kits are various parts & pieces that are intended to correct the tie-rod bind caused by improper geometry in the front suspension.
This improper geometry if generally caused by the lowering of the car below factory spec.'s. Which during suspension travel, causes the arch swing of the tie-rod to be grossly incorrect and some degree of bind can occur. This causes a degree of unwanted steering input.
Early 911's have some bump steer right from the factory, and that gets worse with lowering the car.
The common kits available are either a spacer kit for the steering rack, or a tie-rod end kit that contains new tie-rod & spacers.
What is available for a lowered 965, I do not know. Good luck with your project!
Mark
Old 06-16-2008, 12:03 PM
Thanks for the reply Mark ! AL
Old 06-16-2008, 01:31 PM
A fellow Pelacanite
NathanUK's Avatar
I see no reason why some one does not make the tie rod ends.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-17-2008, 12:19 PM
