Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
LinkBack Thread Tools Rating: Thread Rating: 22 votes, 4.27 average.
How much CFM is needed for 375HP?
Anyone know how much CFM of air is required to support 350 to 400 HP?
Not what size I/C is best.
Old 06-16-2008, 08:47 AM
David's Avatar
What size engine? How much boost?
2014 Cayman S
2011 Cayenne Turbo
Old 06-16-2008, 09:57 AM
3.2 Carrera at 7.5 lbs.
Old 06-16-2008, 10:26 AM
David's Avatar
I used:
displacement x rpm x 1/2 x volumetric efficiency x pressure ratio = cfm
so your engine would be:
193 cu in x 7,000 x 1/2 x .9 x 1.51 = 532 cfm
volumemetric efficiency may be below 90%, but that's what I used to be safe.
2014 Cayman S
2011 Cayenne Turbo
Old 06-16-2008, 10:59 AM
David,
I love this board.
So my minimum CFM for an I/C should be this or more?
Thx!
Old 06-16-2008, 12:25 PM
David's Avatar
I went more than the 749 cfm I calculated for my engine due to the rear placement of the intercooler. Sure an intercooler that's twice as big as it needs to be won't be twice as efficient and may only be a percent or two more efficient, it does give some margin for hot track days.
You'll also hear there's more lag with a larger intercooler, but one expert I talked to said if you go few days between a small and large intercooler you won't even notice any difference.
The big disadvantage to a large intercooler is weight. My intercooler weighs 30 lbs
If you're going to build your own, pay particular attention to the end tanks. I tapered mine across the inlet and exit to help keep the flow even.
As for front to back vs side by side, who knows? On front to back the air moves slower so it has more time to cool while a side to side has more velocity but each passage is longer so it has more surface area to exchange heat. ?!?!?!
2014 Cayman S
2011 Cayenne Turbo
Old 06-16-2008, 03:59 PM
BoxxerSix's Avatar
With all dimensions equal, the side to side(left to right) type flowing core would have a bit more pressure drop than the front to back style flowing core that has the shorter core path. It's why liquid/air IC's have such little to near zero pressure drop as the air passages that the charge air flows over are very short(average 2-4" at most VS 10-24" for various air/air).
A simple HP to CFM formula is:
Wa = HP x A/F x (BSFC/60)
Wa = flow in lbs/min
HP = horsepower target(crank)
A/F = air fuel ratio
BSFC = brake specific fuel consumption....usually estimated around .6
Then just convert to CFM
V = (N x 10.73 x T) / (29 x P)
V = CFM
N= lbs/min
T = Temp degree Rankine.......or outside air temperature plus 460
P = psia
Adam Hennessy
Old 06-16-2008, 06:22 PM
I understand the long IC's create more drag as the air cools and slows down.
Thought this is why CFM rating falls off so fast with added length.
Old 06-16-2008, 08:05 PM
Eric86Red911's Avatar
This turbo calculator will help with CFM calcs:
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc.
Old 06-17-2008, 06:30 AM
David's Avatar
That's a cool site, thanks!
2014 Cayman S
2011 Cayenne Turbo
Old 06-17-2008, 09:23 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
